turbo install help
Old May 29, 2006 | 03:42 PM
94integragsr's Avatar
Banned
Default turbo install help
just go done isntalling my turbo kit and start it up it seems to run good untill i hit boost then it bogs , i have an idea that it has do do with the wastegate. my wastegate has two ports one on the side and one on the top i left the top open and ran the vacume line from the manifold to the side post. is that correct ? when i run vacume to the top port the wastegate opens. im so confused mabye i have the fire ring in wrong i dont know.
Old May 29, 2006 | 03:53 PM
awdgsx96's Avatar
Default Re: turbo install help (94integragsr)
About the last statement, the top port on the wastegate is if you are using a boost controller off of it. You're most likely running rich if you can get enough air to be OK in vacuum. Check for boost leaks, exhaust leaks, etc etc. Is it tuned?
Old May 29, 2006 | 03:55 PM
a1320addict's Avatar
Default Re: turbo install help (awdgsx96)
what ems?
you didn't specify any fuel system specs or an ems, so maybe you're jumping the gun.
Old May 29, 2006 | 03:57 PM
Banned
Default Re: turbo install help (a1320addict)
not tuned yet , hondata
Old May 29, 2006 | 04:01 PM
Banned
it used to work then i just put in a built motor and new manifold , downpipe just got done
Old May 29, 2006 | 05:33 PM
Banned
i think i figured it out--- my ecu does not know how to react with the 3bar map sensor im running hondata , doesnt it need to be reprogrammed to run a 3bar
Integra Type-GSR
Jul 7, 2011 05:17 AM
94c1v1cex
Mar 4, 2008 06:53 PM
Black R
Jan 20, 2005 07:40 PM
rbf351
Dec 17, 2002 06:10 AM
Raz1983
Mar 26, 2002 04:10 PM
