What exaclty does a wastegate do?
Old Mar 21, 2002 | 10:48 PM
Raz1983's Avatar
Default What exaclty does a wastegate do?
Ive been woundering about it for a while now.
What exactly does a waste gate do? Its connected to the exhaust manifold right?
Can someone teach me what it does? (pictures would be nice too)
thanx
Old Mar 21, 2002 | 11:03 PM
2000_Civic_Si's Avatar
Default Re: What exaclty does a wastegate do? (Raz1983)
A wategate regualtes the amount of boost you run!
The wastegate is mounted to the exhasut manifold, best location being where all the primarys come together. Location varys on manifol to manifold. You should also have a vacuum line running to the wastegate.
Say you are running 10psi. The wastegate should stay closed until it gets a reading of 10psi. from the vacuum line. Once, it gets a reading of 10psi. it will start to open a valve which releases exhaust through a dump tube on the backside of the wastegate. This is done to keep only enough exhasut going to the turbo to regulate the 10psi. boost pressure. All the extra exhaust gases will be let out through the dump tube. Most of the time a Turbo kit will come with a Dump tube which vents into the atmosphere and is really loud. This is called "open loop". But you can reroute the dump tube back tpo the exhasut system making it quiet. This way is called "closed loop". Using the closed loop method you may lose like 2hp cause of the disruption of the exhaust flow as it enters into the exhaust piping.
I hope this awnsered what you needed. I may of explained things in a manner that is hard to understand, but I hope you can understand it. Well later.
Old Mar 21, 2002 | 11:07 PM
Raz1983's Avatar
Default Re: What exaclty does a wastegate do? (2000_Civic_Si)
Wow, thanx for your answer!
I kinda understand it except for one place. so, is the wastegate located before the turbine? isnt the turbine located right after the exhaust manifold? so the exhaust gas, goes from wastegate, turbine, and then out?
sorry for all the questions, but i really want to learn how the whole turbo works
thanx
Old Mar 21, 2002 | 11:10 PM
93LSivic's Avatar
Exactly what was said above. To add.
If you want to boost more than you would have to go with some type of a boost controller---weather it be an electronic boost controller or a manual boost controller.
If you choose to boost below the specified wastegate pressure (say the spring is set for .45 bar or about 6 psi), then you would have to go with a lower spring rate in the wastegate itself to be able to boost below that .45 bar pressure.
Old Mar 21, 2002 | 11:18 PM
No problem. People here at http://www.H-T.com are please to help people with your questions. We all have questions at one time or another. So we are glad to help!
Well to get back to the topic. Yes, the wastegate is located before the Compressor Housing. The exhaust gases will come out of the head, flow into the manifold pass "BY" the wastegate and into the compressor housing. and then out the downpipe. Then once the valve opens in the wastegate you will have some of the exhaust gases escaping out the Wastegates dumptube. Which overall the compressor housing will see less exhaust gases. Let me know if you have anymore questions!
Old Mar 21, 2002 | 11:41 PM
Raz1983's Avatar
93LSivic, 2000_Civic_Si
thanx for the answers!
they both answered all my questions i had in my mind!
again, thanx a bunch!
Old Mar 22, 2002 | 12:35 AM
BlueShadow's Avatar
you mean the turbine housing NOT the compressor housing. the compressor is the one that compresses the air and sends it to the intake. the turbine is what's between the WG/exhaust manifold and the downpipe.
Old Mar 22, 2002 | 01:04 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What exaclty does a wastegate do? (BlueShadow)
Im so happy you guys responded with something very good, rather than do a search.
art
Old Mar 22, 2002 | 09:59 AM
Raz1983's Avatar
Default Re: What exaclty does a wastegate do? (Arturbo)
eh? r u trying to be sarcastic?
cause i did a search on it on yahoo and others, but couldnt get good info on it, so i decided to post it, since i know you guyz would have the answer.
just to make sure, the gas flows like this right?
exhaust manifold
wastegate
turbine
downpipe
thanx
Old Mar 22, 2002 | 10:03 AM
BlueShadow's Avatar
exhaust manifold
wastegate
turbine
downpipe
thanx
huh-huh---huh-huh...he said gas...huh-huh
j/k yes that's how it goes
Old Mar 25, 2002 | 09:38 PM
Dorikamu's Avatar
then how does boost controller relate to wastegate.. I suppose if I have a wastegate I dont need a boost controller?
Old Mar 25, 2002 | 09:48 PM
93LSivic's Avatar
Default Re: What exaclty does a wastegate do? (chusai)
The only thing the boost controller will do is allow you to boost more than the wastegate spring. Hence, you can run a turbo without a boost controller, but cant boost more than the wg spring.
Confused yet??
Old Mar 25, 2002 | 09:52 PM
Dorikamu's Avatar
Default Re: What exaclty does a wastegate do? (93LSivic)
then can I boost less than what the wastegate allows with boost controller?
SIK IN DA HED's Avatar
New User
actually.. ive been told that the wastegate spring is for "pseudo" boost. it doesnt regulate boost... it actually prevents boost creep.
Old Mar 25, 2002 | 09:57 PM
93LSivic's Avatar
Default Re: What exaclty does a wastegate do? (dlplayboy)
Oh yeah, I might add! When you are boosting using the wg spring----the turbo in most cases wont come onto full boost as quickly as using a bc. Reason: Because since it is in fact a spring, nothing will keep the wg closed fully (with the exception of a boost controller) until it reaches the boost level its rated at. Another words, it leaks boost the whole time.
Old Mar 25, 2002 | 09:59 PM
Dorikamu's Avatar
yeah, if I cant boost more than the wastegate regulates, what good is a boost controller for?
Old Mar 25, 2002 | 10:01 PM
93LSivic's Avatar
You have it backwards. You cant boost lower than the wg spring. The boost controller is to up the boost.
Old Mar 25, 2002 | 10:26 PM
Dorikamu's Avatar
so wastegate is not used to avoid overboost... it's used to set the lower boost limit?
Old Mar 25, 2002 | 11:12 PM
turbocoupe's Avatar
exhaust manifold
wastegate
turbine
downpipe
thanx
I don't think art is being sarcastic. Lately people have been answering "newbie" type questions with "do a search." I agree with art, it was a simple question but someone actually took the time to give a well thought out answer. This is the HT I know. . .too bad it's not like this all the time. . .
Old Mar 26, 2002 | 02:07 AM
niedejb's Avatar
Confused yet??
I was under the impression that a boost controller kept the wastegate closed 100% until desired boost was reached. Doesnt it interupt the "vacuum" line going to the wastgate actuator and send the signal to open at the last possible second? This would allow you to spool quicker since the WG is closed 100% till then...?
Old Mar 26, 2002 | 05:06 AM
racerxadam's Avatar
Default Re: What exaclty does a wastegate do? (niedejb)
a boost controller manipulates the boost signal that is coming from the boost source. regardless, if the wastegate is able to "see" the amount of boost that is equivalent to the spring that it has it will open and let exhaust pass. a boost controller is basically a restrictor in the line from the boost source to the wastegate and only lets the wastegate "see" less boost than is actually being made. in turn the wastegate does not open and the turbo is allowed to spool longer creating more boost. eventually the turbo will create enoungh boost to allow the wastegate to "see" its spring pressure and it will open to relieve the extra exhaust.
[Modified by racerxadam, 11:01 AM 3/26/2002]
Old Mar 26, 2002 | 05:13 AM
Dee's Avatar
Dee
Default Re: What exaclty does a wastegate do? (racerxadam)
good answer racer!!
Old Mar 26, 2002 | 05:53 AM
Phantom's Avatar
Default Re: What exaclty does a wastegate do? (Dee)
good thread, maybe we can rename to the beginner's turbo FAQ
Old Mar 26, 2002 | 06:19 AM
kenkan's Avatar
is BOV and WasteGate is the same working method?
I know bov make those psssssssssssst sound
Old Mar 26, 2002 | 06:23 AM
DSF's Avatar
DSF
Default Re: What exaclty does a wastegate do? (kenkan)
Technically, yes. All they are essentially are pressure relief valves.
