turbo help? how soon do i need to tune it?
Old 03-21-2004, 09:33 PM
secksiman19's Avatar
Default turbo help? how soon do i need to tune it?
hey guys, i did search b4 i posted, but could not find the answer. im putting a turbo kit on my f22, going to run about 6 psi. and it comes with a vortech rising rate fuel pressure riser and a 255 lph additional fuel pump. my question is using this how long could i run this with out doing some fuel tuning? i might get an afc and just tune it to -35 across the board, i heard this will get me around, but is it safe? i just dont want to run lean!!! and i heard that a/f meters are not taht accurate unless you get a wideband so i dont think im going to tune it by the butt dyno and my a/f gauge. also i will probly need bigger injectors, huh? maybe some prelude ones? thanks for the input-jesse
Old 03-21-2004, 10:19 PM
pissedoffsol's Avatar
Default Re: turbo help? how soon do i need to tune it? (secksiman19)
you really CAN'T tune an fmu setup as you would anything else.
if you get a vafc, do NOT run it at -35%, you will be way out of gas.
running negative numbers means you are running way too big injecotors- and stock are NOT way to big.
Old 03-22-2004, 07:16 AM
Default Re: turbo help? how soon do i need to tune it? (pissedoffsol)
so can i drive on it just with an fmu and maybe bigger injectors? or should i ditch the fmu? i want to drive it for maybe a month or so with no tuning. would that be aite? i know these might be annoying q's but i appreciate all help!
Old 03-22-2004, 12:45 PM
anybody??
Old 03-22-2004, 03:19 PM
FMU + map bypass + stock injectors, or 1 step higher (+50 cc over stock)
-OR-
VAFC at -3x% + 440-ish injectors
xxscaxx
23
01-23-2005 09:11 PM
brandond
04-29-2004 04:47 PM
ZoNe_HKS
09-01-2003 04:31 PM
wzcb08
05-11-2003 07:36 PM
dwilson
07-27-2002 07:01 PM
Quick Reply: turbo help? how soon do i need to tune it?
