Major Oil Problem !!PLEASE HELP!!
Old Apr 18, 2004 | 06:05 PM
QWKVTEC's Avatar
Default Can Anyone Help Me?
I have a turbo off of a '02 WRX on my '92 civic si. My problem is that my turbo is blowing oil through my exhaust and through the compressor into my charge pipe. I have taken the turbo out and had it checked by a local shop. They said everything w/the turbo looks perfect (there is only 10k miles on it). I am wondering if it is possible to be running too big of an oil feed line? At this point I am looking for any helpul input, this thing has got me seriously stumped. THX
Old Apr 18, 2004 | 06:16 PM
Hoosier Daddy's Avatar
Default Re: Can Anyone Help Me? (QWKVTEC)
Usually that would probably mean you have bad turbo seals, but since the shop said everything is good, it's hard to tell. What size is the feed line? What size is your return line? Is it straight? Kinked?
Old Apr 18, 2004 | 09:16 PM
blownD16's Avatar
Default Re: Can Anyone Help Me? (Hoosier Daddy)
His feed line is 1/8 inch hard line and #10 return line
Old Apr 18, 2004 | 09:22 PM
FredoSP's Avatar
Default Re: Can Anyone Help Me? (blownD16)
1. Are you getting excessive blow by?
2. You say #10 return line, Im assuming you mean -10AN? How does your return line look? If this isn't a smooth slope then maybe the oil is backing up causing the seals to blow.
3. How healthy is this motor?
4. What is the setup on this car?
Old Apr 18, 2004 | 09:30 PM
blownD16's Avatar
Default Re: Can Anyone Help Me? (FredoSP)
Yes were getting excessive blow by.
Setup is tdo4 w/10k miles (the thing is brand new). '92 VX manifold Custom Stainless 3'' Downpipe. Stock Mitsu Blow Off. MSD 6 BTM. Prelude SH injectors.(also have DSM 450's) STR Fuel rail Aeromotive FPR W boost Reference.
Return Line Is about as straight of a shot to the pan as you can get w/ no obstructions
Old Apr 18, 2004 | 10:25 PM
blownD16's Avatar
Bump
Old Apr 19, 2004 | 08:29 AM
bluesi00's Avatar
do a compression test
Old Apr 19, 2004 | 08:45 AM
RA166E's Avatar
Where does the return line enter into the pan is it above the oil level or below?
Del$olB16A3
May 31, 2005 04:16 PM
94lsboost
Nov 28, 2004 03:33 PM
Krayzielix
Jul 8, 2004 04:18 PM
Carp
May 8, 2003 04:29 PM
