Turbo gods need help
Old Jul 11, 2011 | 05:57 PM
boostedb20z's Avatar
Default Need some turbo help and suggestion
i have a sc6152e with a .63 a/r this turbo is a 76 trim Inducer-2.795 exducer-2.437
i also have a to4e with a .81 a/r this turbo is a 75 trim Inducer-2.896 Exducer-2.511
Now by the measurements the .81 a/r housing should fit on the sc6152e witch im wanting to go to a .82 a/r so this housing is close enough. Now my question is the sc61 exhaust wheel will not be as tight in this housing as the to4e exhaust wheel is. Is this going to be a big problem ?
Or do i make a hybird sc61 backing plate/wheel and housing on the to4e center section and exhaust housing ? need some ideas trying to make 500whp on this
Old Jul 11, 2011 | 08:32 PM
Default Re: Turbo gods need help
anyone ???
Old Jul 11, 2011 | 09:16 PM
Terrible One's Avatar
fyi, the 6152 .63 a/r is rated at 630hp.
Old Jul 11, 2011 | 09:28 PM
i have a big cam setup that would like to breath thats why
Old Jul 12, 2011 | 11:51 AM
what's your setup?
Old Jul 12, 2011 | 02:55 PM
heres the setup
Bottom End:
B18A1 block stock bore and sleeves
SRP pistons 81mm 10.7.1 comp
.74 head gasket
Eagle Rods
ACL Race bearings
moroso oil pan
Head:
B18A1 head port matched
BC dual valve springs and ti retainers
Crower 404 all motor cams
Edelbrock intake manifold
hondata intake manifold gasket
moroso valve cover
Tranny:
GSR with OBX diff
Stock alxes lol
Turbo setup:
750hp intercooler
SC61
Spa Topmount
50mm BOV
38mm Wastegate
Chassis:
sk2 coil overs if front but used the sk2 sleeves in back on 18k springs
8 point cage
24.5x8x13" slicks
Fuel setup:
A1000 pump
sumped tank
2 earls filters one 100 microns and the other 10
-8 to pump and -6 everything else
aeromotive fpr
BDL fuel rail
ID 1000cc
Old Jul 12, 2011 | 09:24 PM
TheShodan's Avatar
Moderator
Those are rated to the crank.
ArniFPR
Jun 20, 2014 07:01 AM
NemaN
Oct 18, 2012 03:08 AM
MTVtec
Dec 24, 2009 10:06 PM
radeon
Sep 8, 2005 08:18 PM
