turbo fuel injector size
Hi I have a 2000 civic b16 turbo with a. .63 trim turbo kit. Only gonna run 8psi. Found a set of aus high impedance fuel injectors 450cc would this be good?
Man U FTW
Re: turbo fuel injector size
PSI doesn't mean anything. Injectors are sized off your power goal. Also, your .63 trim turbo kit doesn't tell us anything - you gave us the A/R on the turbine housing.
At any rate, since you're looking for 300whp or less, 450s would be ok. Personally, I would look for a set of 550s because you might cap out those 450s
