Turbo fitting problem
Old Mar 11, 2003 | 03:44 PM
metal-x's Avatar
Default Turbo fitting problem
I was trying to test fit my turbo but it won't clear the block
the turbo is a T3 60-1 .63, max rev manifold and the block is a B18B
what can I do? thank
Old Mar 11, 2003 | 03:46 PM
Pengo's Avatar
Default Re: Turbo fitting problem (metal-x)
shave a lil off the block. try running a search, i think this topic has been covered several times in the past. good luck man
Old Mar 11, 2003 | 03:47 PM
paulzy's Avatar
shave the block or turn the turbo the other way
EDIT: spelling
[Modified by Paul_Vang, 12:57 AM 3/12/2003]
Old Mar 11, 2003 | 04:10 PM
dfoxengr's Avatar
Default Re: Turbo fitting problem (Paul_Vang)
u have to cut the block..that little piece offf.
Old Mar 11, 2003 | 04:13 PM
metal-x's Avatar
Default Re: Turbo fitting problem (hybridvteceg)
Ok I see it thanks guys
another quick question what about the dipstick do I just fit it through the manifold?
Old Mar 11, 2003 | 04:17 PM
dfoxengr's Avatar
u can cut some of the top off, to make it shorter
Old Mar 11, 2003 | 04:32 PM
avividmemory's Avatar
shave teh block ro turn teh turbo the other way
thats what i did...except the only problem with that is, now i cant fit a filter on that way lol...
Old Mar 11, 2003 | 04:38 PM
metal-x's Avatar
Default Re: Turbo fitting problem (SpoolinLS)
what do you mean turn it the other way?
Old Mar 11, 2003 | 05:31 PM
BoostedSi's Avatar
Flip it the other way. Bolt the turbo so that the compressor is on the driver side.
Old Mar 11, 2003 | 05:45 PM
SlowB16's Avatar
Default Re: Turbo fitting problem (BoostedSi)
I would flip it the other way. From that picture it looks like you are going to have to take alot off of the block. Just flip it
Old Mar 11, 2003 | 09:48 PM
Pengo's Avatar
yea my friend flipped his instead of shavin the block and somehow managed to get a filter squeezed in there right off of the turbo, no piping.
Fc_v8
Sep 21, 2010 01:01 PM
BOOSTEDgs-R
Feb 17, 2008 04:00 PM
u n v kenny
Jun 7, 2007 07:44 AM
VtecAdil
Jul 27, 2005 09:44 AM
Muckman
Jan 16, 2004 09:31 AM
