Turbo D15B7?
Old Mar 23, 2016 | 12:06 PM
Nelson_'s Avatar
Default Turbo D15B7?
Hey guys i have a silly question.
I bought a eg hatch as a project that now runs smooth as silk. Now that it runs good I'd rather not go through the time and money of a swap (though it may be easy for some of you). I wanted to turbo it but only to about 8-10 pounds. But how would the internals hold up? Or what things should I consider upgrading or replacing to make sure it doesn't blow apart?
As well as where to buy it all..
Thanks
-Ryan
Old Mar 23, 2016 | 12:19 PM
2kdrift's Avatar
Default Re: Turbo D15B7?
Thanks
-Ryan
theres a FAQ you should do some reading
With that said that motor wont handle much power, PSI MEANS NOTHING, its all relative 8 PSI on one turbo is COMPLETELY DIFFERENT from another
I honestly would not turbo that motor, if you want a fast car get a different motor D16Z6 at least, a B SERIES would be much better, I have personal experience and that particular motor is pretty much the worst one to turbo, the rods are too small. I only blew one motor in my life and it was a D15B7
Old Mar 23, 2016 | 01:10 PM
bergercurtis's Avatar
Even a D16Z6, I'd replace the rods. Keeping it D-series would be easiest with motor mounts and whatnot, and the harness would be the same (minus VTEC). B-series have somewhat beefier rods, but D-series usually only hold up to around 200whp (just a rule of thumb). Not worth risking your build parts when connecting rods and piston combos are usually cheap enough and helpful to put power down safely.
Old Mar 23, 2016 | 02:47 PM
2kdrift's Avatar
yea thats the thing with D series you gotta build the block for anything over 200hp, its just about the same price to get a B swap from H motors or something like that and youl be good for 300+
Shade93
22
Dec 8, 2009 06:51 PM
Mar 6, 2008 09:55 PM
blue2000em1
Jul 9, 2007 08:56 PM
Doogie Howser
Sep 5, 2002 02:27 AM
mr2
13
Nov 8, 2001 11:01 PM
