turbo d15 problem help :(
Old May 2, 2010 | 08:59 PM
mrflak0's Avatar
Icon3 turbo d15 problem help :(
heres what i have a stock d15b7 i just replaced the head gasket cuz it was leaking into cylinder 2 toured everything to spec connected everything no problem i put rc 440 injectors it would run right so i put the stock ones back in ran fine no problem then i noticed that when i drive it wont let me rev past 4k after like first gear like its at a fuel cut der no cell up except for 02 sensor cuz i cant connect it but will so does anyone have an ideal what could b doing this????
Old May 2, 2010 | 09:42 PM
Adam_b16a's Avatar
Default Re: turbo d15 problem help :(
Is the car tuned? Im having a hard time understanding what your doing? Is the car running on the stock injectors or the 440's?
Old May 2, 2010 | 09:48 PM
mrflak0's Avatar
no its on the stock ecu and stock injectors
Old May 2, 2010 | 09:49 PM
Adam_b16a's Avatar
And its turbo'd?
Old May 2, 2010 | 09:52 PM
mrflak0's Avatar
yhea i have a t25 with a blox map sensor bypass valve so i dont keep getting the cell for map sensor
Old May 2, 2010 | 09:55 PM
Adam_b16a's Avatar
You shouldnt be driving around untuned in the first place imo. I can almost garranty that all the problems your having is directly related to tuning.
Old May 2, 2010 | 09:56 PM
mrflak0's Avatar
yhea i know im waiting for payday to go get it tuned but thats what it sounds lik a tune to u iv never turbored so im confuesd
Old May 2, 2010 | 10:00 PM
Adam_b16a's Avatar
What you should do is throw away that check valve pos and take the car to the dyno.
Old May 2, 2010 | 10:02 PM
mrflak0's Avatar
yhea im only got it so i can drive to wrk with out the cel coming on and going limp and acting dumb but i do wanna go get it tuned
Boost_em1_
Mar 26, 2014 07:22 AM
jakedrew61
May 2, 2010 11:02 AM
b20turbocivic
Nov 9, 2009 07:28 PM
mdoubleg
Sep 15, 2008 07:30 PM
DelSolMike
Apr 23, 2006 04:48 AM
