So I have a Precision SC34, and when I put it up to my BLOX mani it seems as though the compressor is gonna point straight forward, like at the radiator. Is that the correct direction? Seems like I would want it to face down, as there isn't much room between the block and the radiator.
Whats the optimal direction for the compressor to point for DIY IC piping on a DC?
Clock the housing till you get it where you want it.
GL
GL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddyboy »</TD></TR><TR><TD CLASS="quote">Clock the housing till you get it where you want it.
GL
Yeah, but is pointing down how I want it? And I recieved my SC34 straight from a rebuild at Precision, does me moving around the housing or "clocking" it mess anything up??? Like any seals or balancing they did???
GL
</TD></TR></TABLE>Yeah, but is pointing down how I want it? And I recieved my SC34 straight from a rebuild at Precision, does me moving around the housing or "clocking" it mess anything up??? Like any seals or balancing they did???
Here is a picture of my gt2871r with the compressor housing removed. Notice there are no seals on there. Just loosen the bolts around the housing then spin it to your desired position.
GL
GL
It doesnt mess with anything at all.
Just makes it easier to run piping.
