clocking compressor housing
Old Feb 27, 2007 | 05:47 PM
boostedblkef's Avatar
Default clocking compressor housing
it maybe a stupid question but im trying to get my gm8 turbo to fit right ive already clocked my exhaust housing but the compressor housing wont budge it kinda seems like there like a sealant were it meets and i dont want to break anything any ideas as to why its not turning ????
any help would be greatly apreciated
Old Feb 27, 2007 | 06:16 PM
Yambor's Avatar
rubber mallet?
Old Feb 27, 2007 | 06:39 PM
Default Re: (Yambor)
wow very helpfull i just tapped on it with 1 finger and it didnt move so i posted it in here asking why
Old Feb 28, 2007 | 03:39 AM
Default Re: clocking compressor housing (boostedblkef)
bump
Old Feb 28, 2007 | 03:56 AM
KeyserSoze's Avatar
Default Re: (boostedblkef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedblkef &raquo;</TD></TR><TR><TD CLASS="quote">wow very helpfull i just tapped on it with 1 finger and it didnt move so i posted it in here asking why </TD></TR></TABLE>
Well, why don't you think about it for a second.........unless someone has seen that exact turbo and remembers what it looks like or has had the turbo before they will not know how to clock it. They are a lot of different ways of clocking a turbo, does yours have bolts that hold it to the chra? Is there a big snap ring that holds the comp housing on the chra?? If you really wanted help faster you would post some pictures so people don't have to guess on what YOU should be doing.
Old Feb 28, 2007 | 04:39 AM
Default Re: (KeyserSoze)
pics can be found here
https://honda-tech.com/zerothread?id=1636639
Old Feb 28, 2007 | 06:17 AM
KeyserSoze's Avatar
You losen those bolts around the compressor housing and rotate it.....
If it is stuck you might need to spray the seam with some penetrant (most use wd40 for this, but something like kroil is wayyyy better), let it sit then try to move it. If that still doesn't work then while the bolts are still loose, lightly tap on the compressor housing with a deadblow hammer or a mallot (the first is made out of plastic and has lead shot or sand in it, and the second is made out of hard rubber) and that should break it loose. GL.
Old Feb 28, 2007 | 06:55 AM
bolts are loosned and i sprayed pb blaster and taped with a dead blow hammer already it wont budge and it was freshly taken apart and rebuilt by turbonetics so its not like its old and rusted i dont know i guess ill just beat the **** out of it and hope i dont break it
Old Feb 28, 2007 | 05:54 PM
hmmmm
Old Feb 28, 2007 | 07:59 PM
inspyral's Avatar
Put the CHRA or turbine in a vise, put something like a jack handle into the compressor outlet for leverage, and use that to turn it(carefully). You can wrap a towel around whatever you use to protect the inside of the compressor housing if you want, but you shouldn't need to put it too far in nor use too much force.
Old Mar 1, 2007 | 03:11 PM
Default Re: (inspyral)
so i asume it just needs a little encouragement to turn and not something im missing thanks and ill just put a lil more muscle into it
tech7427
Sep 17, 2008 02:53 PM
ELSpool
Welding / Fabrication
11
Aug 21, 2007 06:15 PM
dnbruut
Jul 8, 2005 07:57 AM
integlspwr2k
Apr 20, 2005 03:48 AM
11psiTurboSI
Oct 13, 2004 06:23 AM
