turbo clutch question
Old Mar 23, 2009 | 10:20 AM
g0tgot's Avatar
Default turbo clutch question
is it reccomended to go with an UNSPRUNG clutch for a turbo LS vtec setup? or is Sprung ok? i heard of the springs coming out on the plate causing issues, from too much HP. please let me know...
Old Mar 23, 2009 | 12:43 PM
E85B18's Avatar
Default Re: turbo clutch question
I run a sprung competition stage 5 with 430 hp and love it. No issues daily driving. What is "too much hp"?
Old Mar 23, 2009 | 12:49 PM
Turbo-LS's Avatar
get a sprung hub disc, you will be sorry if you do a solid disk, its also very harsh engagement and very tough on transmission parts
Old Mar 23, 2009 | 02:55 PM
boostedeg6-1's Avatar
Little be known to most people, the engagement is no different. That is a very common mis conception. The harsher engagement is do to the amount of pucks the disc has and that type of material the disc is made of. I have Had countless #'s of both types of disc's sprung and unsprung they engage the same... Now, a twin disc on the other hand thats a whole nother story. They are great
Old Mar 23, 2009 | 02:57 PM
TheShodan's Avatar
Moderator
Drivability is severely effected if the car is not intended to drag race every light. For best results, use the sprung clutch. Your leg will thank you for it for months and years to come
Old Mar 23, 2009 | 03:10 PM
Turbo-LS's Avatar
The point to a sprung hub clutch disc is to smooth the engagement of the clutch, YES the amount of pucks will also change that but there is a difference bewteen sprung and unsprung, ive had both in the same exact clutch and there is a noticable difference in engagement, but what do i know
Old Mar 23, 2009 | 03:19 PM
nomercy's Avatar
I have a act 6 puck unsprung/extreme pressure plate and I daily drive my car...it's not bad at all besides the pressure plate will build ur leg up...
Old Mar 23, 2009 | 04:34 PM
tech7427's Avatar
if youre going to DD the car and you like to complain about your car, get a unsprung clutch.
but if youre like me and want a smooth engagement, get a sprung disc.
Old Mar 24, 2009 | 04:28 PM
AfTeRhOuRs209's Avatar
act sprung 6 puck, seems to be the best of both worlds... i had a unsprung 6 puck on my dd and couldnt stand it.... i drove it and i drove it without any problems but man did that suck.. got old.. real quick.
Old Mar 24, 2009 | 06:20 PM
igorka_91's Avatar
I learned the hard wat wen my stage 4 6 puck unsprung slutch mesed up mi main bearing in the tranny over time. while racing my friends 3.5 maxima, one of the bolts came lose on the flyweel and started hiting the clutch disc so the clutch wouldnt engage. When i took the tranny of then the presure plate. i hand losened 4 bolts on the flywell lmao. and one bolt was grounded down al the way almost. For dailly driving gett sprung clutch. I have exedy oe sprung clutch in and im loving it for dailly driving on a gsr.
Old Mar 25, 2009 | 08:14 PM
g0tgot's Avatar
thanks guys! i was getting the impression that the spring comes out on a sprung clutch when you start adding more force to it. but everyone seems to be on the same page here, easy clutch= sprung(ok for daily drive) Difficult clutch= unsprung (not daily drive intended) thanks yall!!
jcvelez360
Transmission & Drivetrain
Nov 2, 2010 03:05 PM
90Rexx
Jan 9, 2010 10:08 AM
Mugencrxsir1
Feb 15, 2006 06:37 PM
deeweezy
Aug 4, 2003 07:00 PM
dbman96
May 15, 2002 05:44 AM
