Turbo civic runs good in warm tempatures and bad in cold
I just started to notice this problem last night. During the day it has been in the 70's and the car runs fine full boost through all the gears. Last night when it got cold out(40-50) the car started to have problems. I have never noticed this before. Even throughout winter this was never a problem. I can hold full boost until around 6k and then it starts "cutting out" for seconds at a time but otherwise holds full boost. I'm not sure how to describe it. Its like a "hesitation". Do you have any ideas what is causing this?
My setup is:
Greddy TD04
Tial 35mm external on 9psi
D16y7 with y8 intake manifold
If you need more info please ask.
Thanks,
Zach
My setup is:
Greddy TD04
Thanks,
Zach
Re: Turbo civic runs good in warm tempatures and bad in cold
has it just been tuned or retuned recently?
my retard buddies street tuned when it was warm outside and now when its cold it runs like crap...
a car will run slightly more boost in cooler weather, what you are experiencing is more than likely overboost, i had a car that did exactly the same until i lowered the boost slightly, then it was fine
