turbo b20 a bad idea?
Old Jul 30, 2003 | 01:05 AM
othick's Avatar
Default turbo b20 a bad idea?
I recently shot a rod through my block and was thinking since I need a new block maybe I should upgrade. I was thinking about using a b20 block but I've heard they crack easy. Does anybody have any experience with turbocharging a b20/vtec with stock internals. I'm not looking to do anything crazy, I'm only running 8psi.
Old Jul 30, 2003 | 01:13 AM
liam821's Avatar
Default Re: turbo b20 a bad idea? (othick)
yea they break i dont recommend it unless you sleeve the block.
b20/vtec at 10psi notice where it breaks?
liam
_Endless_'s Avatar
i like to know too. what's the max safety boost for a bone stock CRV b20?
Old Jul 30, 2003 | 02:22 AM
othick's Avatar
nice pic, thanks
Old Jul 30, 2003 | 02:28 AM
Benny Hinn's Avatar
good dyno here, the guy is using the small turbo off of a sohc greddy kit
https://honda-tech.com/zerothread?id=548420
Old Jul 30, 2003 | 08:28 AM
boosted eg's Avatar
Default Re: turbo b20 a bad idea? (_Endless_)
i have a turbo b20b motor and boost is set at .8bar street and 1.3bar on the track with race gas but i have not turned it up yet so i stay at .8bar on the track with pump gas right now trying to get good times at low boost first
Old Jul 30, 2003 | 10:17 AM
quikB18B's Avatar
Default Re: turbo b20 a bad idea? (boosted eg)
I ran b20 vtec turbo for a while only 6.5 psi, it ended up throwing a rod through the block(not boost related) when we pulled motor out the motor looked great. It's was a sad day becaue my block was trrash. We currently use it as a cup holder/ashtray in our garage .
Old Jul 30, 2003 | 11:29 AM
othick's Avatar
Default Re: turbo b20 a bad idea? (quikB18B)
Shooting a rod through my block was not boost related either. It sucks bad my block is destroyed. I feel you pain.
Old Jul 30, 2003 | 01:30 PM
blackANESE's Avatar
Damn man what happened? You've had some bad luck lately.
Old Jul 30, 2003 | 03:08 PM
Charlie Moua's Avatar
well a hondatech member by the name of : DonniEK has a LS with the greddy 15g kit and made a fairly nice setup.
Old Jul 30, 2003 | 06:52 PM
GSRswapandslow
Guest
Posts: n/a
any engine will be fine on mild boost levels IF it is setup properly and the tuning is good.
I've seen many stock block engines boost and boost and never fail. And b20s are included in that.
Old Jul 31, 2003 | 12:16 AM
othick's Avatar
Default Re: turbo b20 a bad idea? (blackANESE)
It never ran right after I hydrolocked it and I think I may have damaged the rod in the process. I do have very bad luck with cars but I'm getting used to it.
Old Jul 31, 2003 | 08:37 AM
T4eg's Avatar
If i was to run a B20 i would get some AEBS t-sleeves just to strengthen it up alittle. It would be fine after that
Old Jul 31, 2003 | 09:16 AM
TwistedHatch's Avatar
Default Re: (BlueHatch00)
i ran 6psi fine on my b20, then the day after i turned it up to 10 the motor lost cylinder number 3, however on 3 1/2 cylinders ran a 12.93 at 104
Old Jul 31, 2003 | 02:04 PM
shermanyang's Avatar
Default Re: (TwistedHatch)
if you're gonna get a B20 and get it sleeved and all that other stuff, you might as well just get a B18a/b and get it sleeved and bored to 84mm. there goes your b20 right there...and a whole lot cheaper as well.
Old Jul 31, 2003 | 07:35 PM
liam821's Avatar
Default Re: (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">if you're gonna get a B20 and get it sleeved and all that other stuff, you might as well just get a B18a/b and get it sleeved and bored to 84mm. there goes your b20 right there...and a whole lot cheaper as well.</TD></TR></TABLE>
You are 100% correct. If your gonna sleeve a b20 you might as well do a b18 to 84mm its the same thing...but cheaper.
The only reason you would want a b20 is for the stamp..hehe...bling bling.
liam
mysterysktr7
Apr 23, 2009 07:51 PM
GoCarInteg
Jul 28, 2005 06:30 AM
SiRk
Jul 21, 2005 10:00 PM
allmotorek8
Apr 24, 2005 02:08 PM
RECRU_SOL2000Vti
Feb 4, 2003 07:41 PM
