Turbo b16
Old Mar 24, 2006 | 12:16 PM
  #26
ham's Avatar
ham
Default Re: Turbo b16 (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">i just made 333whp and 221wtq on my bone stock b16a2 motor, daily driven...ill let u know how long it lasts </TD></TR></TABLE>
ill guess..... 14psi?
Old Mar 28, 2006 | 08:49 AM
  #27
ramtyper19's Avatar
Default Re: Turbo b16 (ham)
New question.....
Can my 255 walbro handle 18psi of boost........
Old Mar 28, 2006 | 09:26 AM
  #28
beerbongskickass's Avatar
Default Re: Turbo b16 (ramtyper19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 &raquo;</TD></TR><TR><TD CLASS="quote">New question.....
Can my 255 walbro handle 18psi of boost........</TD></TR></TABLE>
What "psi" you run means nothing, you need to worry about how much power your making.
A Walbro 255 will support 500whp on the stock fuel lines and 600whp with larger fuel lines.
Old Mar 28, 2006 | 10:09 AM
  #29
jay-d-em's Avatar
wow great numbers guys, i have a b16 powered ek hatch. people always say b16's cant make power. this thread proves wrong.
Old Mar 28, 2006 | 10:23 AM
  #30
slowhonduh93's Avatar
I made 256whp and 178wtq with my setup... crappy xspower manifold t3/t4 57 trim .63 ar turbonetics turbo, and custom 2.5 dp etc... tuned with uberdata.... @9psi
Old Mar 28, 2006 | 11:11 AM
  #31
cobra2326's Avatar
Default Re: Turbo b16 (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">What "psi" you run means nothing, you need to worry about how much power your making.
A Walbro 255 will support 500whp on the stock fuel lines and 600whp with larger fuel lines.</TD></TR></TABLE>
I dont think power is directly related to fuel flow either? What about 500whp at 11:1afr compared to 500whp at 12:1?? Those are going to require different amounts of fuel.
As for the latter statement, Im not sue why that would make sense. If the pump is rated at 255lph, why would increasing the size of the lines help? I could be wrong on this one though...
Basically, your walbro can flow 255lph. Do some calculations using injector size and fuel pressure and that should tell you if you're maxed out.
Old Mar 28, 2006 | 11:40 AM
  #32
Default Re: Turbo b16 (cobra2326)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cobra2326 &raquo;</TD></TR><TR><TD CLASS="quote">
Basically, your walbro can flow 255lph. Do some calculations using injector size and fuel pressure and that should tell you if you're maxed out.</TD></TR></TABLE>
Here are a couple good threads about it...
http://forums.evans-tuning.com/viewtopic.php?t=367
http://forums.evans-tuning.com/viewtopic.php?t=668
Old Mar 28, 2006 | 02:30 PM
  #33
ramtyper19's Avatar
thanks guys I am just going for 400hp... So i guess i would be fine...
1sikhatch
Jan 19, 2012 03:44 PM
b16ajdmrex
May 23, 2009 09:20 AM
hmongxcuz
Nov 28, 2007 12:56 AM
Barbantus
Oct 7, 2007 07:45 PM
killerbeee16
Jan 8, 2004 08:21 AM
