which turbo
Old Oct 5, 2004 | 07:08 PM
fl_hmong_racer's Avatar
Default which turbo
i am currently runnign a t3t4 from the drag kit and would like to uprgrade. i was wondering if u turbo expert on here could give me some idead on which turbo to go with. i want to make int he 350 whp and want the spool to be nice and decent. my setup is as follow.
gsr motor with 9.5:1 compression, eagle rods, rc 750cc, JG mani, hondata s200... so if u guys could help, that'll b nice. thanx
Old Oct 7, 2004 | 05:02 AM
Default Re: which turbo (fl_hmong_racer)
bump
Old Oct 7, 2004 | 01:34 PM
XxRoCkMaNxNEOxX's Avatar
how much hp u got right now. from the looks of ur setup you can achieve it w/ the turbo u have. what stage wheel does it have?
Old Oct 7, 2004 | 01:46 PM
RyanEJ8's Avatar
The T3/T4 you have now should easily make 350whp. There's no reason to upgrade.
Old Oct 7, 2004 | 06:21 PM
Default Re: which turbo (RyanCivic2000)
it once made 360whp at 17lsb,but the tunningreally suck,and since then i now have 327 at 14lbs, but in need of tunning. the turbo has a 50 trim. is there a better turbo then this one that would spool faster then this one but still make a lot of power?
Old Oct 7, 2004 | 08:41 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fl_hmong_racer &raquo;</TD></TR><TR><TD CLASS="quote">it once made 360whp at 17lsb,but the tunningreally suck,and since then i now have 327 at 14lbs, but in need of tunning. the turbo has a 50 trim. is there a better turbo then this one that would spool faster then this one but still make a lot of power?</TD></TR></TABLE>
Not really, the T3/T4 50 trim is one of the faster spooling turbos for that power level. Moving to a bigger turbo will make spool worse and if you move to a smaller turbo you most likely won't be able to meet your power goals. I would definately stick with the turbo you have. Get someone to tune it right.
Old Oct 8, 2004 | 07:21 AM
thanx...
Old Oct 8, 2004 | 07:27 AM
RyanEJ8's Avatar
No problem, I notice you are in Tampa. Just curious who originally tuned your car?
Old Oct 8, 2004 | 10:40 AM
john from ss tuned it first and made 360WHP at 17lbs which in my opinion is too high for my set up, and plus the car ran like shiet. then i got it tune my sfp after changing the piston and rods. and made 260whp at 9lbs and i was told that my injector were too dirty to go any higher, so i got them cleaned and got them back and put my car on the dyno and made 327whp at 14lbs but now my car is running too lean, so i called sfp and they said to tune is again, but i don;t wanna deal with them anymore( kind too far). so i am thinking bout letting this guy name Mase from gainsville tune it, but i am still getting my last part together, and the turbo is the last part. ther u go, the whole history on my car, i know u didn;t ask for the whole story lol, but ii just thought that i'd give it here on H-T.
Old Oct 8, 2004 | 11:03 AM
RyanEJ8's Avatar
John knows what he is doing. Why do think 360whp at 17 lbs was too high for you setup?
CustomX113
Nov 20, 2006 09:27 AM
fl_hmong_racer
Oct 7, 2004 12:52 PM
deeweezy
Nov 8, 2003 07:57 AM
AsianMullet
Oct 25, 2003 11:56 AM
boostin b16
Apr 17, 2003 02:31 PM
