tuning/fuel system questions
Old Oct 7, 2011 | 05:28 AM
1988montecarlos's Avatar
Default tuning/fuel system questions
ive been thinking about turbo'ing the b18b in my 96 civic sedan recently and was wondering what id have to do regarding the ecu/tuning it. what would be my best bet without breaking the bank?
and how much power will the stock fuel system/injectors support? id be shooting for about 275whp on 91 octane (thats the highest we have up here)
if thats over what the stock fuel system would support, what would i have to get regarding that? (what size pump, injectors etc. and if id need different rails/lines or a regulator)
thanks for any help you can offer!
Old Oct 7, 2011 | 05:35 AM
Muckman's Avatar
Moderator in Chief
Default Re: tuning/fuel system questions
Because you bought an OBD2 car you need to get an OBD1 ecu to run Hondata/Neptune/Crome and a harness adapter. I have a chipped OBD1 P72 for sale that you can use for any tuning software you choose.
The stock injectors are tiny. Youll need bigger injectors. I suppose 440cc would work but Id go with the largest you could afford to give you room to grow in the future - ID1000s. And you'll need a real fuel pump. A walbro 255 will be fine. The stock lines and rail are fine.
Old Oct 7, 2011 | 05:39 AM
is it possible that my car is already running an obd1 ecu? and how would i tell?
Old Oct 7, 2011 | 05:46 AM
Muckman's Avatar
Moderator in Chief
Is it stock? If it came with any aftermarket injectors then I would bet it is retund and therefor ODB1. But you could pull the ECU out and figure out what it is.
Old Oct 7, 2011 | 08:33 AM
SilverEK96's Avatar
yeah just pop off the cover on passenger side, and look at the ecu, if there is a harness bridging your ecu to your stock wiring harness then its a obd1 ecu, if its pluged in directly your still on stock ob2 ecu
Old Oct 7, 2011 | 11:03 AM
i guess i got lucky, it does have an obd1 ecu in it, heres a pic of the numbers on the side, could i use this ecu? and if i could what would i have to buy for it to run a turbo?
Old Oct 7, 2011 | 11:09 AM
Builda'Teg_92's Avatar
sure can
Old Oct 7, 2011 | 11:28 AM
TheShodan's Avatar
Moderator
You have an LS P75 Non-vtec ecu. You can use Hondata, Neptune RTP, etc. Check with Hondata.com and their ECU list of information regarding which ECUs you can use. I believe that the P75 can be converted to run VTEC
Old Oct 8, 2011 | 05:29 AM
if i was to buy a hondata s100 for this ecu, is there anywhere i could send it to, to get it tuned if i gave them all the info on my setup?
Old Oct 8, 2011 | 07:54 AM
SilverEK96's Avatar
what they can do is put a base map just to get your car running in the right direction, but for tuning you'll have to go to a tuner and get dyno tuned
Old Oct 8, 2011 | 08:29 AM
Last edited by 1988montecarlos; Oct 8, 2011 at 08:41 AM. Reason: answered my own question
sydistik
Engine Management and Tuning
16
Mar 31, 2015 04:19 PM
ja20_eg
Sep 19, 2012 11:14 AM
jrs2ksi
Nov 22, 2006 05:33 PM
fobile missile
Feb 24, 2005 12:00 PM
J337_UNIT
Jan 22, 2004 12:53 PM
