what fuel components do i need?
Old Nov 22, 2006 | 03:41 PM
jrs2ksi's Avatar
Default what fuel components do i need?
I am boostin my civic and i want to know what to do for my fuel? I will be running about 8-10 psi. What upgrades from stock will i need?
thanks
-Jordan
Old Nov 22, 2006 | 03:49 PM
Dunc's Avatar
BCICAN
Default Re: what fuel components do i need? (jrs2ksi)
Walboro 255 in tank or a similar pump of your choice and some injectors that are sufficient for your power goals (and a way of controlling them). Pretty much everything else will be fine.
Or if you want to upgrade further, grab a pressure regulator and a rail.
Old Nov 22, 2006 | 04:23 PM
shortyz21's Avatar
Default Re: what fuel components do i need? (AF-P Dunc)
injectors..
nothing wrong with the stock fuel pump and 450cc's..
thats it.
Old Nov 22, 2006 | 05:08 PM
jrs2ksi's Avatar
Default Re: what fuel components do i need? (shortyz21)
what injectors should i go with?
Old Nov 22, 2006 | 05:26 PM
Topdawgg's Avatar
550's probably...
nothin wrong with buyin more expensive bigger ones.. you can always run them at a lower duty cycle...
its better to have lots of fuel instead of not enough
walbro 255 pump and some injectors is all you need...
Old Nov 22, 2006 | 05:29 PM
xenocron's Avatar
Default Re: what fuel components do i need? (Topdawgg)
What year is the Civic?
If 96+ you are going to want:
- Conversion Harness to convert to OBD1
- OBD1 ECU
- Larger Injectors (440cc would be enough for 8-10 psi)
- Fuel Pump is certainly a good idea
After that, all you need is tuning...tuner directory is at the top of this forum!
Old Nov 22, 2006 | 05:32 PM
jrs2ksi's Avatar
Default Re: what fuel components do i need? (xenocron)
2000 civic b16
Old Nov 22, 2006 | 05:33 PM
Topdawgg's Avatar
like the man said.... you will need a conversion harness obd2b to obd1 and run obd1 computer... thats your best bet... easiest
90civicgsr
Feb 7, 2008 06:17 AM
deucedeuceEK
Jun 2, 2007 04:33 AM
buckysi
Mar 6, 2006 03:54 PM
jeremy.
Sep 29, 2003 05:35 PM
PTL
Jun 7, 2003 12:53 PM
