Tuning a B16A1 for T3/T4 Boost and Meth injection
Setup for a B16A1 (Boost and Meth injection)
Hey people,
im helping a friend of mine with his turbo setup, this is his setup at this moment. is there a thing in the list we should upgrade or something whe should watch out for.
Turbo Setup:
* T3 turbo
* Equal length Header (B16/B18)
* 35 mm Tail wastegate
* Blow off Valve ( turboxs ??? dont know )
* Downpipe with wastegate fitting 2.50" (v2a Stainless steel)
* Charge piping 2,25" (v2a ss)
* SSteel oil lines
* Methanol turboCooler (incl. 20 Ltr Methanol)
* Vortech 12:1 FMU ( this will be removed )
* Walbro 255 intank fuelpump
* Div. silicon Hoses and Couplers
We want to run this setup with a stock block a 8 psi and after we installed a sureguard to around 12 psi without the FMU and with 450 cc injectors with a OBD0 to OBD1 conversion and using Uberdata on a p30 ecu.
This setup was bought from a guy who had money troubles, so we diddnt choose the parts for this setup. so all the comments about the parts are welcome.
some pics made by previous owner.
for more pics check : http://www.honda-vti.de/turboeinbau.htm
Greetz Erwin
ps sorry for my bad english.. but if you want you can try and type Dutch back to me whahahaha :D just kiddin
Modified by toxicshit at 2:38 PM 8/9/2004
Modified by toxicshit at 2:39 PM 8/9/2004
Modified by toxicshit at 2:41 PM 8/9/2004
Turbo Setup:
* T3 turbo
* SSteel oil lines
Greetz Erwin
Re: (toolowsol)
why should i throw the Turbo in the trash whats wrong with it can you give me some info to go with that comment
The guy would only sell the complete kit so this is what is have and i post to know what i should upgrade in the future.
Re: (toxicshit)
What kind of manifold is that? It looks like an SSAutoChrome, which I don't have any personal experience with, but from what I've heard, they are peices of ****. Everything else looks ok though
Re: (Poop111444)
the manifolds sometimes hjold up its kind of a give or take but so far the turbos all trash out in the 1st month.
its recommended by J. davis to get it balanced locally and itll be a godo turbo.
Re: (Thermodynamic)
The manifold is fine if you brace the turbo and exhaust properly. Well, except for boost creep issues. The turbos are terrible but I have heard of them working fine after a professional rebuild and dynamic balancing.
...And I hope you aren't injecting methanol. Methanol vapor will kill you.
Re: (Poop111444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poop111444 »</TD></TR><TR><TD CLASS="quote">Just have the manifold braced (weld some support brackets to take the weight off the manifold)</TD></TR></TABLE>
the previous owner allready braced the manofild
Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">And I hope you aren't injecting methanol. Methanol vapor will kill you.</TD></TR></TABLE> Would it be smarter for me to use Ethanol ? i was thinking about it because its less Corossive that MEthanol.
Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">its recommended by J. davis to get it balanced locally and itll be a godo turbo. </TD></TR></TABLE>
Ok i know J.Davis i a verry good source of info and thrust his info for 100% ill tell the owner to send his turbo to Turboworld and get is Balanced
Thnx for the info Guys your a big help in findind out that parts ar good and wich arnt good at all
Greetz Erwin
Greetz Erwin
Re: (toxicshit)
Yes, Ethanol is harmless. Methanol is deadly. After your body absorbs it is starts eating away at your nerves. The optic nerve is the first to go. First blindness, then numbess, then death.
Also Ethanol is easier to get and has the same chemical properties.
Re: (toxicshit)
I know several people running master power turbos for some miles without issue, there's nothing wrong with them. Meth is a better fuel than Ethanol, you'll make more power running it than you will running ethanol. Be very careful around the stuff and you'll be fine.
Re: (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">Throw that turbo in the trash... </TD></TR></TABLE>
Then throw the trash in the trash, then pee on it.
Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">Yes, Ethanol is harmless. Methanol is deadly. After your body absorbs it is starts eating away at your nerves. The optic nerve is the first to go. First blindness, then numbess, then death.
Also Ethanol is easier to get and has the same chemical properties.</TD></TR></TABLE>
ok thats a verry strong point ill look into using ethanol.
Re: (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe »</TD></TR><TR><TD CLASS="quote">I know several people running master power turbos for some miles without issue, there's nothing wrong with them. Meth is a better fuel than Ethanol, you'll make more power running it than you will running ethanol. Be very careful around the stuff and you'll be fine.</TD></TR></TABLE> i know i can make more power with meth but i dont like the blindness part of it so ill settle for a little less cooling
And ill send the turbo to be Balanced just to be sure that i dont get anny troubles.
Does annyone know what kind of Blowoff valve that is?
Greetz Erwin.
Greetz Erwin.
Re: (toxicshit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toxicshit »</TD></TR><TR><TD CLASS="quote"> i know i can make more power with meth but i dont like the blindness part of it so ill settle for a little less cooling </TD></TR></TABLE>
There's a half empty 55 gallon drum of meth sitting in my garage right now, me and both of my room mates arn't blind so I think you'll do fine with meth IIRC Meth is usually cheaper than Ethanol too.
Re: (swlabhot)
i know the wastegate some otherfriends of mine have them.
But the blow off valve is un know to me?
we have 20 liters of Meth left when that cannister is empty well buy Ethanol.
Should i use 50/50 Meth Water ?
i ♥ my honda
Global Mod
Global Mod
Re: Setup for a B16A1 (toxicshit)
That hole kit is junk
I bet the WG is not even tial. If it is than that is the only thing I would keep.
This looks EXACTLY like the ssautocrome Ebay sales. I am actually pretty sure it is.
They make there own WG/and BOV that are look alikes and work poorly
If you got it used I woud say its proly already fuxxed.
I would pay maybe 300$ for all that (only if it was a real tial)
