Is tt ok to run 18 lbs on a fairly stock head??
Old 09-25-2004, 12:54 PM
BuiltTurboCoupe's Avatar
Default Is tt ok to run 18 lbs on a fairly stock head??
ok i got a fully built bottom end but a igot a b16 head with port and polish on it, with all GSR internals, now is it ok to run 18 lbs on thta kinda head?? if not should i get springs and retainers? or just aftermarket valves?? let me knwo please thanks
Old 09-25-2004, 12:56 PM
11psiTurboSI's Avatar
Default Re: Is tt ok to run 18 lbs on a fairly stock head?? (BuiltTurboCoupe)
yes people make over 400hp with stock heads... just dun rev past 8000rpm!
Old 09-25-2004, 04:50 PM
m R g S r's Avatar
I have a stock GSR head with 80k miles, and my rev limit is set to 8500rpm's. Granted I don't rev that high everyday, but I do make max power at 8200.
The amount of boost you run won't weaken the head at all, but the stock porting will just become a limiting factor when you get into the 500+ range.
Old 09-25-2004, 06:35 PM
TurboR1391's Avatar
Default Re: Is tt ok to run 18 lbs on a fairly stock head?? (m R g S r)
I would at a minimum replace the stock retainers with titanium. I had a stock retainer let go in my Type R head. It took my complete head and my 2.0 liter C5 block with it.
delsol8017
01-01-2009 11:01 AM
laziebun
01-19-2008 09:51 PM
dunkd
02-27-2005 09:12 AM
servion
10-20-2002 10:37 PM
bigTom
07-26-2001 11:08 AM
Quick Reply: Is tt ok to run 18 lbs on a fairly stock head??
