Is this true about oil???
Old Oct 15, 2002 | 10:25 AM
integra-modder's Avatar
Default Is this true about oil???
Just curious what you gurus think...
"Most engine wear occurs in the few seconds after the engine has started, before oil has reached moving parts. "
Old Oct 15, 2002 | 10:47 AM
Tofurky's Avatar
Default Re: Is this true about oil??? (integra-modder)
it just means warm up your mothereffing car
Old Oct 15, 2002 | 10:49 AM
b18bturbo's Avatar
Default Re: Is this true about oil??? (Ruckus138)
it is true. most damage occurs to lack of oiling. Thats why the best setup is prelube setup with dry sump system. of course that cost money and most people dont have that much dough to dump on deisgned oil system. But for the avg joe they sell some devices that prelube the engine.
SiRkid's Avatar
true...a dry start up.....those are the worst few seconds for your motor..
Old Oct 15, 2002 | 10:51 AM
The_Head's Avatar
Yes its true. The few seconds from startup until you get oil pressure is when alot of wear occurs because the most of the oil is in the pan and hasnt made it through the engine yet.
Somebody makes this kit you can buy, its an electric oil pump system or something like it. Before you start your car it turns on and gets the oil pressure up so the oil is circulating throughout the motor, so everything is oiled before you run the motor. I forgot the website, but it was kinda pricy, like $400.
Old Oct 16, 2002 | 07:04 PM
Default Re: Is this true about oil??? (xThexHeadx)
well what would this 400 bucks buy you? 10,000 miles more on your motor?
jc
D
Old Oct 16, 2002 | 07:23 PM
MikeMAN's Avatar
anyone know where to find this kit?
Old Oct 16, 2002 | 08:19 PM
pelotudo's Avatar
Default Re: Is this true about oil??? (MikeMAN)
Can this be caused by turning over the engine a few times before starting? I.E. Have a kill switch going to my MSD 6A box, so that I can crank the car w/o having the coil spark and would allow it to get some moving in there before it actually starts? (It would also be a nice kill switch for thieving ******). Or does it have to be flowing before any oil will get up there?
jB
Old Oct 16, 2002 | 08:25 PM
TheSwift1's Avatar
jc
D
exactly my thoughts...
Old Oct 16, 2002 | 08:38 PM
mos's Avatar
mos
Default Re: Is this true about oil??? (TheSwift1)
Even when I let my car sit for weeks then pop the valve cover off.. everything looks damn oily up there. I'm not worried about start up wear.
Old Oct 16, 2002 | 10:09 PM
The_Head's Avatar
Default Re: Is this true about oil??? (mos)
http://www.enginelube.com/ProductFrameSet.htm
A 30 second search on MSN sent me to the above webpage... Interesting quote from McDonnell Douglas on the top of the page.
Here is the system I was referring to before that costs $400
http://www.prelube.com/
Is it worth it? How much life will it add to your motor? I don't know. Honda motors seem to last a long time without prelube systems.
Old Oct 17, 2002 | 04:56 AM
symba's Avatar
That was an interesting quote...Made me think...But, my Lude is a 96 that I bought brand new so every bit of the 91,xxx miles are mine. Would something like that make a difference now? I would think that most of us here have cars that are 3+ years old.. I think the damage has already begun by then and that system would best serve cars that are newer like within the first 2 years..Just my .02
Old Oct 17, 2002 | 09:26 AM
Default Re: Is this true about oil??? (symba)
well you create heat friction anytime you start on rubbing surfaces without oil, so i think it would matter at any point during the car's life span.
globy123
12
Oct 18, 2009 03:01 PM
citrus3000psi
Mar 3, 2008 08:07 PM
carboy_honda
11
Aug 21, 2006 01:15 PM
93LSivic
Feb 27, 2004 02:13 PM
lke2drvgsr
Jan 3, 2004 12:12 AM
