trouble clocking tubo
Old Jun 5, 2004 | 09:07 AM
Dawson21's Avatar
Default trouble clocking tubo
alright, so i am having trouble getting the oil return to face straight down. The only way i can move the center cartrige is to remove 4 10mm bolts. These bolts won't go in unless the return is about 45 degrees from being straight down.
Any suggestions.
Old Jun 5, 2004 | 09:29 AM
Rod.'s Avatar
Default Re: trouble clocking tubo (Dawson21)
loosen the bolts on the turbine side. It should have like a little plate under the screws that look like ( ). Then clock it
Old Jun 5, 2004 | 09:47 AM
Dawson21's Avatar
Default Re: trouble clocking tubo (redturbocivic)
i lossened that but that only allows the turbine to move with the center. I need the center to move freely from the turbine.
Old Jun 5, 2004 | 10:02 AM
espanol's Avatar
what's a tubo?where can i get one.does artubo sell one?
Old Jun 5, 2004 | 01:26 PM
Dawson21's Avatar
wtf....
anyway can someone help me out
Old Jun 6, 2004 | 02:50 AM
LBR92DA-T's Avatar
when you loosened the turbine housing the center wouldn't clock? is it an old turbo?
Old Jun 6, 2004 | 07:58 AM
DaX's Avatar
DaX
Loved
Community Favorite
If this is a DSM turbo, you're going to need to pull the compressor cover off and file down the tab that's keeping you from clocking it.
g2turbo
Mar 10, 2016 04:24 AM
Tippyman
Jun 1, 2007 02:53 PM
redDAinteg
Jun 26, 2006 03:49 PM
mnlude
Mar 7, 2006 10:22 AM
delslo93
Jan 23, 2005 12:31 PM
