tricking sensor?
Old Nov 28, 2001 | 03:26 PM
TurBoTeG's Avatar
Default tricking sensor?
How do you trick the MAP sensor to not see boost...i know you can use the "missing link", but how would you do it without it???
Old Nov 28, 2001 | 03:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: tricking sensor? (TurBoTeG)
With check valves..
art
Old Nov 28, 2001 | 03:35 PM
DirtyLude's Avatar
Default Re: tricking sensor? (Arturbo)
Or an electronic MAP limiter.
[Modified by DirtyLude, 4:35 PM 11/28/2001]
Old Nov 28, 2001 | 03:51 PM
TurBoTeG's Avatar
Default Re: tricking sensor? (DirtyLude)
what is Check Valves?? ive been tryin to figure it out..
Old Nov 28, 2001 | 03:53 PM
D-SPEED's Avatar
little things that bleed off boost before the map sensor
Old Nov 28, 2001 | 03:55 PM
dustin's Avatar
Default Re: tricking sensor? (D-SPEED)
Check valves are the little.. uhm.. valves that you use when you have an aquarium to prevent water from flowing back into the air pump. They (relatively) work for turbos too
Dustin
Old Nov 28, 2001 | 03:57 PM
LsTurbo91's Avatar
Default Re: tricking sensor? (dustin)
one way valve it lets pressure out but not air in
shaggyeg6si
May 15, 2008 07:48 AM
_VTI-R_
Feb 28, 2003 01:44 PM
turbotec
Feb 26, 2002 03:34 PM
