trans choice
Old Mar 16, 2009 | 12:29 PM
jdmcivicracer89's Avatar
Default trans choice
im going to be running 8psi on my b16 in my em1. currently have a b16 trans wit a lsd... would a gsr trans with a lsd be a better option???
Old Mar 16, 2009 | 02:28 PM
boosted94gsr's Avatar
Default Re: trans choice
Yes the gsr trans is a better option. The b16 trans gears are a little too short. The way I understand it the longer gears of the gsr trans will help spool the turbo better.
Old Mar 16, 2009 | 03:45 PM
TheShodan's Avatar
Moderator
They both work. For most street/strip applications, either one can work the same 99% of the time. The "longer gears" don't help the turbo spool better. old myth. Those "longer gears" are in 2nd, 3rd and 4th, I believe. check the transmission dial in ratios for each transmission type. The gearing for the B16 is pretty stout considering its lack of torque characteristics.
Old Mar 16, 2009 | 04:00 PM
Blown90hatcH's Avatar
Keep the b16 tranny. If you are having traction problems, use a boost by gear setup / electronic boost controller, not a longer geared tranny as a bandaid. My car went 150mph with the ITR tranny. The gsr tranny is a great all around tranny for most setups, but since you have the b16 in there, I would keep it.
Old Mar 18, 2009 | 09:31 AM
150mph??? is that even possible with that trans? wut rpm where u at?
Old Mar 18, 2009 | 10:31 AM
EARLdaSQUIRREL's Avatar
official honda whore
with 8 psi i would keep the b16 trans if you can stand the rpm's on the freeway, i personally have a b16 trans and with 375whp i just spin untill 4th gear so i want to switch to a gsr trans since i drive alot on the highway and i can't stand cruisin @ 4,000rpm at 70mph
Old Mar 18, 2009 | 10:53 AM
Yes. thru the traps in 4th gear at 9700rpm. 24.5x15" slick.
Get a better boost controller and LS 5th gears. LS 5th gears ~ $100 bucks.
Old Mar 30, 2009 | 02:14 PM
Cole D's Avatar
Do you have the 4.4 fd itr tranny or 4.7?
Old Apr 5, 2009 | 03:02 PM
bada9's Avatar
id say gsr with an lsd and anti-lag and launch at high rpms but keep the b16 and see how it works out first
Old Apr 5, 2009 | 05:19 PM
Originally Posted by cole d
do you have the 4.4 fd itr tranny or 4.7?
4.40
Old Apr 6, 2009 | 04:59 PM
Cole D's Avatar
That car has to be fun to drive around town when properly setup on boost by gear. You are using avr boost controller right? I wonder if the hondata s300 with aem controller will work equally as well?
rick_rabies
Aug 6, 2009 08:48 AM
eg_franchise
Jul 17, 2008 08:11 AM
B16-CRX
Jan 12, 2007 11:55 AM
smokerz212
19
May 6, 2006 06:10 PM
EFMAN
Dec 28, 2005 04:04 PM
