Traction Bars with I/C piping?
Old May 25, 2006 | 11:21 AM
Mr. Vapor's Avatar
Default Traction Bars with I/C piping?
ive "heard" they are not compatable....can anyone confirm? especially the Ek/EJ/EM1 guys.
Old May 25, 2006 | 12:21 PM
nickromeo's Avatar
Default Re: Traction Bars with I/C piping? (Mr. Vapor)
i did it in my sohc goodluck it takes a while to mock it up properly
i had 3'; dp on dirvers side and 2.5 inch charge piping go accross the bottom where the rad support is then turn down and around just beside the washer fluid bottle then into the intercooler
3" dp barely clears the traction bars actually i had to poound the **** out of it with a hammer to get a dent large enough to clear in the spot where it would touch the traction bar.
yah so the intercooler piping on mine goes above the traction bars then when it gets to just before the washer bottle turns down and around. 180 style with a few 45s in the mix.
no AC
it was a bitch.
but its possible i dont have a digital camera so i cant get pics but goodluck
Old May 25, 2006 | 12:30 PM
Mr. Vapor's Avatar
Default Re: Traction Bars with I/C piping? (nickromeo)
ughhhhhh not what i wanted to hear lol....
Old May 25, 2006 | 01:05 PM
Dialectic's Avatar
I was able to do it on my EM1. We just had to cut the drivers side IC pipping to get to the compressor side.
The piping would hang too low, below the traction bars causing the IC piping to scrape if you went over anything taller than an inch and a half, and if you cut the angle right, you can go right above the bars and not under them.
I have ac w/ a 2.5" DP, so its not that big of a deal...on an EM! that is.
Old May 25, 2006 | 01:26 PM
B18 CYA's Avatar
wierd, i have Full Race traction bars and everything clears fine. no problem mocking up my chargepipes and downpipe
Old May 25, 2006 | 04:23 PM
siblues's Avatar
Default Re: (B18 CYA)
Hey i have some pics of the full race bars on an em1 that might help so if you still need them just pm me
eddyboy
May 30, 2007 06:42 PM
platinum00
Jan 20, 2006 11:28 AM
delslow94
Oct 15, 2003 10:44 AM
mattcalica
Jul 19, 2003 07:37 AM
