tracking the boost leak?bov flange?
Old Jun 19, 2006 | 11:33 PM
importdude2000's Avatar
Default tracking the boost leak?bov flange?
atp turbo greddy bov flange..
its a two peice
one welds on
then the acutal flange threads on to the welded peice
i was wondering if it was spose to be weleded after threaded in place?
also
using a 7.25 lb spring
and will only boost 4lbs
all vacs are tight
tbolts are tight
vac is routed like this
wg lower port to compessor nipple
bov to T into fpr solinoid. which goes to im directly
boost guage T into FPR and goes directly to IM
also have a dump that goes next to the dp facing the floor
used the flexable piping thing at autzone... i think i tightend the bolts and the U bracket down..but if that leaks will it cuase me to boost only 4?
gonna check turbo bolts and dp tomaro
might have to drop the dam crossmember to do so
also will a leak on the airfilter going to the turbo cuase it to boost 4?
i dont think my worm clamp on the turbo inlet is tight becuase the turbo rests on the little metal that is under the engine code
Old Jun 20, 2006 | 11:30 AM
help?
v8killaz
Sep 9, 2014 01:50 PM
TravisBiggie
Mar 1, 2013 05:59 PM
EJ1 wilcox
Feb 3, 2007 10:32 PM
vtec25
Nov 15, 2006 08:50 PM
greyzone
Oct 20, 2001 11:17 AM
