Ignition retard
Old Mar 10, 2003 | 11:16 AM
swlabhot's Avatar
Default Ignition retard
Somehow I'm under the impression that if I retard the ignition timing at the distributor manually, the ecu will learn over time and automatically correct the timing back to stock is this true?
Old Mar 10, 2003 | 11:19 AM
Chris N's Avatar
Default Re: Ignition retard (swlabhot)
No, I don't believe this is true.
If you set your base timing to 16 degrees (or lower or higher), it should stay put.
Old Mar 10, 2003 | 11:25 AM
Big Phat R's Avatar
knock sensor will retard timing if there is pinging - but I don't think there is anything built into the system to advance timing - that would be dangerous.
Old Mar 10, 2003 | 11:28 AM
sgT's Avatar
sgT
incorrect
Old Mar 10, 2003 | 11:31 AM
swlabhot's Avatar
Default Re: Ignition retard (sgT)
I'm boosting 6.5psi on stock block. So its OK to retard at the dist a few degrees just to be safe?
Old Mar 10, 2003 | 11:32 AM
Chris N's Avatar
That would be OK to do.
Old Mar 10, 2003 | 11:43 AM
swlabhot's Avatar
Default Re: Ignition retard (Chris N)
Cool! So how many degrees per pound of boost? 0.5, 0.75 ?
Old Mar 10, 2003 | 01:32 PM
Big Phat R's Avatar
Your boost level should be related to your compression and intake charge temperature. I would leave your ignition timing stock and use a J&S Safeguard instead.
http://www.jandssafeguard.com/index.html
Old Mar 10, 2003 | 02:27 PM
swlabhot's Avatar
Default Re: Ignition retard (Big Phat R)
Hmmm...interesting. Thx for the info.
xcountrirunr
Dec 1, 2004 08:57 AM
CRXLST
Oct 27, 2004 09:45 PM
boost fed ls
Jul 20, 2003 09:43 AM
rudebwoy
Mar 29, 2003 08:55 AM
98civicEX
Jun 27, 2002 10:44 AM
