obd1, variable ignition timing without standalone?
Old Aug 10, 2003 | 05:26 PM
TraKtioN's Avatar
Default obd1, variable ignition timing without standalone?
Just as it says, possible? I'm going to be boosting so I cant afford to detonate my motor.
If not, how about this...I understand afc causes the timing to advance when you lean the fuel, soo....if I retard the timing mechanically (odb1) enough to give me enough headroom for increased timing at high rpm, then I should be golden?
Old Aug 11, 2003 | 11:03 AM
TraKtioN's Avatar
Default Re: obd1, variable ignition timing without standalone? (TraKtioN)
anyone??
Old Oct 5, 2005 | 04:22 AM
NoobEH2's Avatar
You could run two different ROMS. More facts are needed to help you out. You say you're boosting your motor, but is it a d-series, B? What kind of internals, if any? You shouldn't need to have two modes of running your car, one good tune'll do you, just don't boost your motor too much in relative to what your block can handle. When in doubt, run it richer
Old Oct 5, 2005 | 04:30 AM
JSPECSIR's Avatar
msd makes a boost timing master that will retard ignition from 1-3or4? degrees per pound of boost. summitracing .com sales it. their is more than one version for stock or aftermarket ign. cost is about 185 I think but if you have a computer uberdata is cheaper and easier
I CRX I
Engine Management and Tuning
15
Mar 27, 2009 06:44 PM
xcountrirunr
Dec 1, 2004 08:57 AM
CRXLST
Oct 27, 2004 09:45 PM
swlabhot
Mar 10, 2003 02:27 PM
echo999
Jan 3, 2003 12:27 PM
