Timing belt issues
Old May 4, 2003 | 05:25 PM
420aNT's Avatar
Default Timing belt issues
My timing belt is riding off the cams by about 1/4 of an inch. What did I do wrong? I have retensioned the belt over and over but it always moves out about 1/4" and rubs on my timing belt cover? My car is a 2001 GSR Turbo with a built bottom end and the head is done with all Ferrea valve train. I tried both the stock cam gears and aftermarket with no change in the position. Someone please help. no one in the Tech section is replying to me.
_______
Old May 4, 2003 | 05:30 PM
speedworks's Avatar
Default Re: Timing belt issues (18gTeg)
did the machine shop resurface the head
Old May 4, 2003 | 05:32 PM
420aNT's Avatar
Default Re: Timing belt issues (speedworks)
yeah it was resurfaced. I had the builder b18bturbo use a head gasket to make up the difference that was milled though. I was told it was to the stock level now with the thicker gasket.
Old May 4, 2003 | 05:41 PM
speedworks's Avatar
the reason i asked is that if the machine shop did not get the head level in the milling machine more material could have been removed from one side of the head (no. 1 cylinder side) which would cause the belt to try to ride off of the cam gears. another suggestion is to check and make sure the timing belt washers are
on each side of the crankshaft gear
Old May 4, 2003 | 05:51 PM
Pengo's Avatar
did u try turning the crank counterclockwise a couple of teeth to get some more tension before u tighten down the tensioner?
Old May 4, 2003 | 06:38 PM
420aNT's Avatar
Default Re: Timing belt issues (Pengo)
yeah the tension is fine. It's just the sliding off thats the problem
420aNT's Avatar
timing belt washers?
Old May 4, 2003 | 06:43 PM
bottlefedb18c1's Avatar
i just put a set of cam gears on my car about a week ago and i beilive there was something like that but not shure to be exactly and it seems like if there was something there and it is not there now means that it is going to ride off
Old May 4, 2003 | 06:44 PM
420aNT's Avatar
Default Re: (bottlefedb18c1)
even if I did not use the washers on the cams why would the belt be rubbing on my cover? It rubs all over the cover.
Old May 4, 2003 | 06:57 PM
Default Re: (18gTeg)
does it rub on the motor side of the cam gear or the opp. side?
Old May 5, 2003 | 05:59 AM
420aNT's Avatar
It rubs on the motor mount side of the cams.
Old May 5, 2003 | 08:13 AM
RGAZ's Avatar
New User
Crank alignment spacers are missing or installed incorrectly.
I know you didn't touch these, but it sounds to me like the spacers that surround the timing belt on the crank side are installed wrong, or missing.
Either that or you have the worst case of crank-walk I have ever heard of. Almost 1/4"!!
Randy
Shaguar47
11
Apr 29, 2007 07:26 AM
TegR
Mar 1, 2007 07:54 AM
unknown0001
Sep 1, 2006 03:33 PM
unknown0001
Sep 1, 2006 03:32 PM
.RJ
May 8, 2003 10:45 AM
