ANY disadvantages to using thicker headgaskets??
Old Nov 18, 2002 | 12:17 PM
TheSwift1's Avatar
Default ANY disadvantages to using thicker headgaskets??
Are there any disadvantages to using a thicker head gasket for a turbo application? i'm thinking of using a Cometic 0.040" gasket to bring my compression ratio to about 9.5:1 (JE 9.8:1 comp. pistons, B18C block, B16A head)
also, i'll be using ARP head studs...
considering the stock gasket is 0.029", i'm not doing too thick on the gasket, but i'm still concerned if this setup will be ok for 9-14psi...(300-350WHP)
Old Nov 18, 2002 | 02:25 PM
TheSwift1's Avatar
Default Re: ANY disadvantages to using thicker headgaskets?? (TheSwift1)
ttt
Old Nov 18, 2002 | 02:28 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Changes cam timing, you need cam gears to offset having a thicker gasket..
Old Nov 18, 2002 | 04:45 PM
red cx's Avatar
Default Re: ANY disadvantages to using thicker headgaskets?? (Rguy)
timing is a main factor. It will have to be advanced in some way.
Old Nov 20, 2002 | 06:13 AM
TheSwift1's Avatar
ok, so it'll change cam timing...will it affect ignition timing in any way? are u speaking of ignition timing b16aturbopwrd?
Old Nov 20, 2002 | 06:57 AM
Boostfed's Avatar
New User
It does affect the quench area in your combustion chamber, can't really go into detail on how it affects it, you want a good quench for combustion purposes. InlinePro has great success with their own thicker headgaskets sooooooo......
D16SohcVtec
Dec 31, 2007 11:00 AM
N1 Andy
Nov 4, 2006 01:32 PM
jdm ek9 101
Sep 12, 2006 07:00 AM
bitchin camaro
Jan 22, 2005 01:29 PM
copper
Feb 1, 2004 09:51 PM
