Is it time for a new TURBO!?!
Old Feb 20, 2008 | 06:34 PM
vTeC2's Avatar
Default Is it time for a new TURBO!?!
I was reading all the turbo leaks or problem on here and i seem to have the same situation. I decided to order a rebuild kit. Open up the turbo and remove seal and seal rings and all and notice it that only thing missing was the O-Ring/Gasket for Compressor Housing, I decided change it with the new seals anyway. Got the car to work again drive it maybe less than 100miles the car smokes again, and only leak on EXHAUST housing and no leaks else where. I do use a restricted return.
Old Feb 20, 2008 | 07:22 PM
OMG B16's Avatar
Default Re: Is it time for a new TURBO!?! (vTeC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vTeC2 &raquo;</TD></TR><TR><TD CLASS="quote">I was reading all the turbo leaks or problem on here and i seem to have the same situation. I decided to order a rebuild kit. Open up the turbo and remove seal and seal rings and all and notice it that only thing missing was the O-Ring/Gasket for Compressor Housing, I decided change it with the new seals anyway. Got the car to work again drive it maybe less than 100miles the car smokes again, and only leak on EXHAUST housing and no leaks else where. I do use a restricted return.</TD></TR></TABLE>
Do you mean a restricted feed line? The Return should be at least a -10an and be free flowing.
Old Feb 20, 2008 | 07:29 PM
vTeC2's Avatar
Default Re: Is it time for a new TURBO!?! (OMG B16)
Yes, i was meant to say the oil feed.
Old Feb 20, 2008 | 08:09 PM
OMG B16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vTeC2 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, i was meant to say the oil feed. </TD></TR></TABLE>
ok. How does your return line look? Where are you getting the feed from? What restrictor do you use? And what size feed line?
Did it stop when you "rebuilt" the turbo?
Old Feb 20, 2008 | 08:15 PM
vTeC2's Avatar
Iam using Stainless oil feed (-3) and oil drain (-10) lines.
It stopped then after driving car for atleast 50-100 miles then it just came back.
Im using the oil feed and lines from my peakboost kit.
http://www.turbokits.com/image...t.jpg
Old Feb 21, 2008 | 09:04 AM
quick26's Avatar
i had an issue with mine blowing oil out the tail pipe/exhaust side and smoking, even after a turbo rebuild. come to find out i did not have a large enough vent on the crank case. i added ventalation to the valve cover and it stoped immediately. make sure your return line is as short as can be from the turbo to the pan and is all down hill with no low spots.
Old Feb 21, 2008 | 09:12 AM
97_coupe's Avatar
What turbo are you using? You might need to run an oil restrictor.
http://www.atpturbo.com/Mercha...e=BCS
Old Feb 21, 2008 | 02:37 PM
vTeC2's Avatar
Default Re: Is it time for a new TURBO!?! (97_coupe)
Im using a Garrett T3/TO4E.
Old Feb 21, 2008 | 03:44 PM
TheShodan's Avatar
Moderator
Pics would help. Anything less is speculative. Could be a kinked line, tapped to the wrong spot. feed from a different area of the block, bad turbo, anything. the more info you give us, the more we can give you in return.
Old Feb 21, 2008 | 04:46 PM
vTeC2's Avatar
Default Re: Is it time for a new TURBO!?! (TheShodan)
I have pics, Wow just noticed after pics that i do see little oil on the turbine housing side
*My brother has an extra t3/t04e but has an 5bolt exhaust flange.. was wondering if swaping it to my 4bolt will work??
Modified by vTeC2 at 6:08 PM 2/21/2008
Old Feb 21, 2008 | 05:37 PM
HondaCivicSiR1's Avatar
where is your oil restrictor?looks like a 90*fitting to me.
Old Feb 21, 2008 | 07:06 PM
OMG B16's Avatar
Default Re: Is it time for a new TURBO!?! (HondaCivicSiR1)
That dosent look like a -3an line to me. It might be the picture though...
Old Feb 21, 2008 | 07:25 PM
vTeC2's Avatar
Are you saying its feeding to much oil? Car was daily driven for a year. Probably put atleast 5-8k on it. Then the leak started, But a rebuild should stop it for awhile .
Old Feb 21, 2008 | 07:32 PM
97_coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe &raquo;</TD></TR><TR><TD CLASS="quote">You might need to run an oil restrictor.
http://www.atpturbo.com/Mercha...e=BCS</TD></TR></TABLE>
Old Feb 21, 2008 | 07:37 PM
XSIintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vTeC2 &raquo;</TD></TR><TR><TD CLASS="quote">Are you saying its feeding to much oil? Car was daily driven for a year. Probably put atleast 5-8k on it. Then the leak started, But a rebuild should stop it for awhile . </TD></TR></TABLE>
Your not serious are you? Fix the turbo, fix your over pressure issue......No rebuild next year
Gunner142
Apr 1, 2009 08:01 PM
VTEC_Viking
Jul 10, 2008 02:28 PM
jgrogan
Oct 4, 2007 09:07 AM
tyrone27
May 9, 2004 04:28 PM
b18c1-ek
Jun 27, 2001 07:08 PM
