Tilton Fluid Control valve fitment with Scattershield
I have a maxzworkz (however you spell it) shattershield and i cant find anywhere to mount the fluid control valve properly. any ideas? how are you guys running it? im running a s2k master, -3 stainless line to a stock slave
Re: Tilton Fluid Control valve fitment with Scattershield
I am pretty sure boostedcivicsir has one on his car, I am sure he will see this thread..... IMO is doesnt do much.
you can mount it anywhere in line between the master and slave. It doesnt have to be directly on the slave.
i know it can be mounted anywhere but it doesnt screw into the master cylinder and it wont fit where the slave is, i think i might just cut my line and get 2 more fittings and slap it somewhere in between
Mr. Badwrench
i had a hydraulics shop make me another line (because they will not mod a used line) with the -3 females in line.
ben is right i really saw no difference. i broke a trans installed the valve and broke another 4th gear in 5 passes. (it was a stock non treated gear.)
i have another racer stev 4th gear in there. im just prolonging the inevitable.
this is it in a nut shell, but with 2 -3 fittings.
https://honda-tech.com/forums/drag-racing-36/how-make-braided-clutch-line-eg-chassis-diy-w-part-numbers-2239907/
Same here.... for now.
I'd skip the FCV if I were you. I had bad results with mine when I started making more power. The slip caused a LOT of excess heat.
So you're out of the shootout? What do you need? Need help? Any chance of you making it?
chris89
Transmission & Drivetrain
11-14-2014 06:53 PM
.water
04-03-2006 07:56 AM
