tight budget build
Old Aug 10, 2003 | 08:23 PM
phatrick2332's Avatar
Default tight budget build
im build a d15b2, I dont have money for new rods or pistons. What should i do to safely run 7-8 lbs of boost, piston and rod wise?
thanks
pat
Old Aug 10, 2003 | 08:36 PM
rjardy's Avatar
Default Re: tight budget build (phatrick2332)
tune it. save your money for ems or hondata. get it tuned by someone who knows what they are doing.
Rob
Old Aug 10, 2003 | 08:42 PM
s-afc and injectors already, but i need to know about rods and pistons. Should i get the rods peened or should i just run them? they are like new, this engine was babied.
Old Aug 10, 2003 | 09:06 PM
tegasaurus's Avatar
Default Re: (phatrick2332)
if you're running an afc and injectors, no need to get pistons, they wont save the **** poor tuning of the afc from blowing up your motor. Run the stock internals till the bastard blows to high heaven. Then spend your money on pistons, rods and a real fuel system.
Old Aug 11, 2003 | 04:32 AM
tell me what fuel management i should use on a small budget..say..400 bucks just for that
Old Aug 11, 2003 | 07:02 AM
RGAZ's Avatar
New User
A zip SMC and a used MSD 6BTM. Total should be under $400.
You get fuel recurve and timing retard. Two helpful tuning methods.
Randy
Old Aug 11, 2003 | 12:44 PM
where do i find the zip SMC ?
any other options?
thanks for the replys
Old Aug 11, 2003 | 07:00 PM
anyone?
Old Aug 11, 2003 | 08:29 PM
Chamois's Avatar
http://www.hondata.com/prices.html
shami
Old Aug 12, 2003 | 02:31 PM
i dont really want to go obd1. I think im just gonna run the afc with dsm 450s and the MSD BTM. That should easily be able to contol everything at only 7psi right?
Old Aug 12, 2003 | 02:36 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">im build a d15b2, I dont have money for new rods or pistons. What should i do to safely run 7-8 lbs of boost, piston and rod wise?
thanks
pat</TD></TR></TABLE>
If you cut corners you pay the penalty! I would suggest waiting untill the time is right.
ty521825
Sep 10, 2012 06:36 AM
cehcivic15
Jan 26, 2009 11:38 PM
EH3forlife
Sep 23, 2006 07:38 AM
Turbo D' Sol
Feb 11, 2004 10:28 AM
the_0ne
Jan 17, 2004 07:14 AM
