tial wg question (fire ring)
Old Jul 17, 2007 | 10:24 PM
powerdbygarrett's Avatar
Default tial wg question (fire ring)
if anyone is awake right now i really need to know what part of the wg bolts onto the manifold. is it the part with the fire ring (bottom) or the side part. i just cant remember. thanks
P.S almost forgot. is the fire ring on the wg supposed to sit flat or does it go the other way. thanks
Old Jul 17, 2007 | 10:33 PM
VRD^don's Avatar
Default Re: tial wg question (powerdbygarrett)
yeap..fire ring side bolts on to the manifold
Old Jul 17, 2007 | 10:37 PM
mighty137's Avatar
just like VRD said!!
Old Jul 17, 2007 | 10:38 PM
and its supposed to go flat into the wg correct?
Old Jul 17, 2007 | 10:49 PM
DecentCivicZ6's Avatar
B A N N E D
dunno what you mean flat into the wg....you put it under the wastegate and bolt it down, it will raise the inside valve up 1/4inch if that......i remember i installed mine with out the fire ring when i first got it....hahhah...i was pissed off thought i got beat out of a WG
Modified by DecentCivicZ6 at 12:29 AM 7/18/2007
Old Jul 18, 2007 | 01:54 AM
90sedan's Avatar
The valve seat will seat flush in there. If you put it in backwards, the valve won't close all of the way.
bradabu
May 25, 2013 06:58 PM
TheWhiteHatchProject
Jun 5, 2008 04:25 PM
DC-4-Drew
Oct 26, 2005 04:39 PM
operatic
Jan 6, 2005 09:58 PM
