Tial wastegate bolts SUCK!!
Old 04-13-2002, 09:02 PM
MiraiZ's Avatar
Default Tial wastegate bolts SUCK!!
I lost the first set...they must of popped off while I was driving...luckily, the sticky gasket that I used kept the wg from falling off completely.
Today..as I was driving, I noticed that my WG was getting noticeably louder and exhaust fumes were coming in from my vents...I thought holy doggy doo...somethings up here. I checked...and bingo! the WG bolts were coming loose and the wastegate was riding up on the bolts....I tightened them down again but...has anyone experienced this? Am I suppost to use red liquid locktite or something to keep this thing down..
By the way, how can you open WG peeps stand that sound!!! ??? Sound horrible...as if I had like 3 engines underneath my hood!! ehk!
[Modified by MiraiZ, 3:03 PM 4/14/2002]
Old 04-13-2002, 09:14 PM
int3gra's Avatar
Default Re: Tial wastegate bolts SUCK!! (MiraiZ)
"I thought holy doggy doo"
Old 04-14-2002, 05:04 AM
MiraiZ's Avatar
Default Re: Tial wastegate bolts SUCK!! (int3gra)
TTT anyone?
Old 04-14-2002, 05:21 AM
austrian type-R's Avatar
Yes, had 2 times the same problems. Now I use a Loctite bolt paste. Same with downpipe bolts here from the DRAG III kit.
Old 04-14-2002, 10:29 AM
IVANITR's Avatar
Default Re: Tial wastegate bolts SUCK!! (austrian type-R)
Same thing happens to me, but I haven't fixed it yet. I do have lock washers on there.
Old 04-14-2002, 12:26 PM
New User
GruvyTune's Avatar
what gasket are you using for the wastegate? I didn't get one with the fmax kit and am not using one at all. I occasionally have a little carbon residue near my connections for my wastegate to manifold and turbo to manifold. I used special high temp threadlock for these and they are not loosening.
Is it normal to have a few very tiny leaks? I get good spoolup so I don't think any leaks I have could be substantial. Can you recommend a good gasket and part no. for the tial?
thanks
Torin
Old 04-14-2002, 12:52 PM
New User
TurboSedan's Avatar
Default Re: Tial wastegate bolts SUCK!! (GruvyTune)
http://www.roadraceengineering.com/f...andgaskets.htm
It is toward the bottom, the Delta Gate gasket. Will fit the Tial fine too.
Old 04-14-2002, 01:51 PM
New User
SIK IN DA HED's Avatar
i like it!
Old 05-26-2002, 02:38 PM
New User
Default Re: Tial wastegate bolts SUCK!! (dlplayboy)
anyone figure out a way to keep the bolts from coming loose? im plannin on gettin the tial wastegate and i want to make sure i dont get the same problem.
Old 05-26-2002, 03:07 PM
BLKCRX's Avatar
The day i put my turbo kit on.. i had the same problem........
the solution was red locktite.. and yeah they don't move now !!! solid as a rock.
Regards James
Old 05-26-2002, 05:45 PM
shadowdawn's Avatar
Default Re: Tial wastegate bolts SUCK!! (BLKCRX)
I haven't had a problem with bolds loosening yet and I have a rev hard manifold and tial wg.. I did however snap a bolt in the 1 side of the tial where it meets where a dump tube would go... best I could do was drill through it and put a MUCH smaller bolt and lots of washers... no mani, dump pipe, or downpipe bolts have come loose on me yet.... ::knocks on wood::
Old 05-26-2002, 05:50 PM
racerxadam's Avatar
can you put studs in where the bolts normally go? if so then i would put studs in and then use two nuts on each stud. tighten the first nut and then tighten the second one against the first so that they are pushing against each other. just an idea
Old 05-26-2002, 07:39 PM
Default Re: Tial wastegate bolts SUCK!! (racerxadam)
studs ownz my wastegate and downpipe
Old 05-26-2002, 07:42 PM
Etylorcen's Avatar
Same **** happened to me. I bought a new set at kragen and used some loctite. My dp bolts were fine.
LagunaSecaEG
07-09-2005 11:16 AM
93dx--hatch
05-07-2004 07:24 AM
integranator
09-09-2003 08:30 AM
Cramerox
05-23-2003 11:50 AM
Etylorcen
02-16-2002 07:03 PM
Quick Reply: Tial wastegate bolts SUCK!!
