throwing map sensor
Old Dec 14, 2001 | 05:25 PM
Andrew 825SM's Avatar
Default throwing map sensor
The shop just told me they finished installing my greddy turbo on a 2000 gsr and everything is running great, but also informed me that the car is idling really bad due to something related to the map sensor. Now I need the car tomorrow and I'm wondering if it would do more damage than harm if I took the car out of the shop and drove it to work or just call in sick for work and leave it in the shop till monday.
Old Dec 14, 2001 | 05:28 PM
1's Avatar
Default Re: throwing map sensor (NHB Fighter)
What shop did you get the kit installed at?
Old Dec 14, 2001 | 05:49 PM
IMPATIENT's Avatar
Default Re: throwing map sensor (1)
did they forget to install the missing link........
Old Dec 14, 2001 | 05:55 PM
b18cTurbo's Avatar
you can drive your car but DONT BOOST cuz your blue box and map sensor is not working properly so your gona be lean
and btw 2000 gsr is obd3 so your blue box is working only whit obd2
you need to convert your whire to obd2
good luck
Old Dec 14, 2001 | 05:56 PM
IMPATIENT's Avatar
Default Re: throwing map sensor (mikvtec)
i agree, don't boost until that **** is fixed......
Old Dec 14, 2001 | 10:55 PM
adam's Avatar
2000 gsr is obd2, there is no obd3
Old Dec 15, 2001 | 12:13 AM
BlueShadow's Avatar
Default Re: throwing map sensor (IMPATIENT)
did they use the stock map sensor? how much boost are you running?
the stock honda map sensors are only good for about 2 BAR above vacuum. thats about 14 PSI, but I wouldn't go above 10 PSI on the stock ones.
Old Dec 15, 2001 | 05:54 AM
b18cTurbo's Avatar
Default Re: throwing map sensor (BlueShadow)
2000 gsr is obd2, there is no obd3.
well here in canada there is obd3 i have a civic si 2000 and its obd3
Old Dec 15, 2001 | 07:11 AM
ekb18c's Avatar
Just use check valves if your throwing map sensor code. Put like 3 chekc valves before the map sensor. If three doesnt work then put 4. That should solve the problem. Honda arent suppose to read boost, so you can trick it by putting check valves in.
HTH
Old Dec 15, 2001 | 11:03 AM
IMPATIENT's Avatar
Default Re: throwing map sensor (ekb18c)
damn, that's alot of check valves........
crazy_ls_90
Sep 10, 2008 02:26 PM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
EK k kay
Nov 2, 2006 01:04 PM
rice a roni
Sep 16, 2005 10:37 AM
B16Civic93
Apr 2, 2005 09:39 AM
