GM 3 bar map sensor?
Old Sep 7, 2008 | 11:13 AM
crazy_ls_90's Avatar
Default GM 3 bar map sensor?
I have a gsr Turbo Civic and i wanna run more boost, iam running 10psi now, i heard that the stock map sensor on a honda will only read to 11psi or so. What do i Need besides the GM map sensor, and how do i install it????? Thanks
Old Sep 7, 2008 | 01:20 PM
mtber's Avatar
Default Re: GM 3 bar map sensor? (crazy_ls_90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazy_ls_90 &raquo;</TD></TR><TR><TD CLASS="quote">I have a gsr Turbo Civic and i wanna run more boost, iam running 10psi now, i heard that the stock map sensor on a honda will only read to 11psi or so. What do i Need besides the GM map sensor, and how do i install it????? Thanks</TD></TR></TABLE>
You are correct the stock map sensor maxes out at 11 psi.
The omnipower/hondata map sensor listed on: https://honda-tech.com/zerothread?id=2188596
Is the ideal solution. Direct bolt on replacement, no wiring, reads up to 43 psi accurately etc.
Direct link to our website: http://www.phearable.net/shopp....html
A GM 3 bar would work just as well but will require wiring & plumbing of vacuum line.
Modified by mtber at 5:39 PM 9/7/2008
Old Sep 10, 2008 | 01:09 PM
Default Re: GM 3 bar map sensor? (mtber)
What is the difference between the Hondata 4 bar and the Omni? thanks
Old Sep 10, 2008 | 02:26 PM
twkdCD595's Avatar
nothing to my knowledge or understanding, somone correct me if I am wrong... just a different casing brand stamp on top.
EK k kay
Nov 2, 2006 01:04 PM
teddy_dc2
Aug 8, 2006 07:51 PM
Si Shane
May 24, 2005 01:14 AM
whagkangmakulet
Dec 18, 2001 11:06 PM
austrian type-R
Sep 1, 2001 05:16 PM
