Those w/boost controllers: How do you switch from low boost to high boost?
Old Jan 7, 2005 | 08:47 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Those w/boost controllers: How do you switch from low boost to high boost?
-what boost controller are you using?
-are you using the greddy profec-b switch?
-can the profec-b switch be used with, say, an Apexi AVC-R (using their A and B boost options)?
-do you have any boost spiking/creeping issues?
Thanks in advance
Old Jan 7, 2005 | 09:39 AM
Burke's Avatar
Banned
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (boostincoupe)
i use 2-way 3port pnuematic switch i bought from grainger that is hooked up to a little red button next my e-brake. ebc for less than $30!
Burke's Avatar
Banned
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (Burke)
one goes straight through and the other one goes through a manual homedepot boost controller
Old Jan 7, 2005 | 09:43 AM
95GSRTT
Guest
Posts: n/a
I use the profec b remote button. I have it attached to my shifter, but I wanna some how get it hooked up to like my cruise control or a horn button. is there a way to even do that?
Old Jan 7, 2005 | 09:50 AM
TeStUdO's Avatar
Wow Burke we almost have the same avatar.
Bump for the Mooninites
Old Jan 7, 2005 | 10:24 AM
t3h_sl0w's Avatar
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (TeStUdO)
Hehe turbo XS dual stage...low to high with flip of a switch...and i got it for 50 bucks
Old Jan 7, 2005 | 10:37 AM
Bulldogg83's Avatar
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (t3h_sl0w)
AVCR....no switching between High and Low boost here....just utilize the Boost by Gear option.
Old Jan 7, 2005 | 10:45 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (Bulldogg83)
i just drive on the street at 30 lbs and c16.....i dont have to switch ****.
Old Jan 7, 2005 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">AVCR....no switching between High and Low boost here....just utilize the Boost by Gear option. </TD></TR></TABLE>
Me wants
Old Jan 7, 2005 | 11:10 AM
PM-Performance's Avatar
i made my own version of the Greddy switch and cost me about .50cents
Old Jan 7, 2005 | 11:44 AM
Finland's Avatar
I really liked my Blitz SSBC that I had on one of my Talons. It had a button for low/high boost level, it worked great.
I don't know if they still make that but it wasn't too expensive.
Old Jan 7, 2005 | 12:40 PM
10secivic's Avatar
Default Re: (ForceFedDetroit)
I use the Blitz and also use the gear option, i can have up to five settings at different mph of boost up to 200 MPH
Old Jan 7, 2005 | 01:02 PM
FORCED FED TEG's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">i use 2-way 3port pnuematic switch i bought from grainger that is hooked up to a little red button next my e-brake. ebc for less than $30!</TD></TR></TABLE>
Did the same thing here but I put switch on my shifter.
Old Jan 7, 2005 | 01:04 PM
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (FORCED FED TEG)
Question: Can the profec-B switch be used with other boost controllers, like the AVCR or Blitz boost controller?
adictionbass's Avatar
hey itr206, how did you make a greddy like switch. Aren't you practically forced to use the greddy switch due to the way it connects to the boost controller?
Old Jan 7, 2005 | 01:11 PM
Bulldogg83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Question: Can the profec-B switch be used with other boost controllers, like the AVCR or Blitz boost controller?</TD></TR></TABLE>
You could cut the connector off of the Greddy Switch and use it on the AVCR considering there are only two wires that you need to hook into on the AVCR.
You could cut the connector off of the Greddy Switch and use it on the AVCR considering there are only two wires that you need to hook into on the AVCR. </TD></TR></TABLE>
Good info
Old Jan 7, 2005 | 01:12 PM
Bulldogg83's Avatar
Good info </TD></TR></TABLE>
Not a problem. As long as you get a momentary switch, anyone will work.
Not a problem. As long as you get a momentary switch, anyone will work. </TD></TR></TABLE>
Do you have any links I can read on how to do this?
Old Jan 7, 2005 | 01:14 PM
hey boostincoupe, do you have a greddy switch you can do that with? Ill buy the connector of off you
Old Jan 7, 2005 | 01:15 PM
Default Re: Those w/boost controllers: How do you switch from low boost to high boost? (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">hey boostincoupe, do you have a greddy switch you can do that with?</TD></TR></TABLE>
I was thinking about buying a Greddy Profec B switch and using it to switch between low boost and high boost on the AVC-R.
Bulldogg83's Avatar
Do you have any links I can read on how to do this? </TD></TR></TABLE>
No links for it. Just simply by going to Radio Shack or any electronics store you can ask them for momentary switch. They only cost around $.30 to $.90 and they usually have 3 or 4 different types. If you really wanted to get stealthy on it you could find the wiring diagram for your horn on your steering wheel and make that your high/low switch if done correctly.
Old Jan 7, 2005 | 01:17 PM
well i just ordered one, but only because you pretty much have to with the profec type S since its a greddy connector. What i originally wanted to do was to use one of the horn buttons to switch back and forth. If you want to use the switch, ill buy the connector off you so i can wire it up with my horn button BTW they are on backorder right now....
95dc2teg
Nov 2, 2012 05:42 AM
bb6kid22
Engine Management and Tuning
Nov 1, 2010 05:03 PM
85
Sep 1, 2010 12:59 PM
scspeed
Mar 26, 2009 03:30 PM
blwn95civic
Apr 5, 2007 09:41 AM
