Need to lower compression.......
Old May 5, 2007 | 07:37 AM
egeeb16's Avatar
Default Need to lower compression.......
Car is a 2005 RSX w/ a Greddy Kit. I want to run lower compression becasue i plan on running more boost. Right now im running 8psi and I just ordered 650cc injectors and a 255 Walbro, also Im getting a tune and i should be at 10psi. But i know if i lower the compression ill be able to run more boost. I also have plans of getting a bigger and better turbo set up. Does anyone have any input a lower compression kit i should use, or does any one have one they may be willing to sell.
Thanks this will be a big help....
Old May 5, 2007 | 07:58 AM
adseguy's Avatar
Default Re: Need to lower compression....... (egeeb16)
When you lower compression you will make less power that's why you can run more boost. Just keep your compression and run higher boost anyway. Get it tuned and be done with.
Old May 5, 2007 | 09:34 AM
purpleh22's Avatar
Default Re: Need to lower compression....... (adseguy)
Heard somefeedback from the machinist/engine builder I use, that thicker gaskets have a negative effect on quench. I know lots of people use thicker gaskets.?????
crxhybrid1320
Mar 17, 2010 02:44 PM
scspeed
Jul 24, 2008 03:53 PM
slowcrx954
Nov 23, 2006 07:49 AM
PePpeRedDc5
May 22, 2005 09:36 AM
RooskiGSR
Feb 28, 2005 04:23 PM
