Thermostat problem
Old Apr 12, 2016 | 08:22 AM
thugsbryan's Avatar
Default Thermostat problem
Guys I'm having a problem that is puzzling, i have a b16 motor boosted, i have never used a thermostat in it, but now I decided to install one, problem is wenever i put it in the fans won't come on an d car starts to overheat at idle, but once I take back out the thermostat the fans come in, I used a gates thermostat and a stock one and d same problem, the thermostats are working cause I boiled them in water an they opened plus wen i took it out of the engine while it still hot it was open, the car fans work fine without the thermostat but they won't come on once I put it in, im using a stock fab switch, and running Neptune engine management,
Old Apr 12, 2016 | 11:31 AM
2kdrift's Avatar
Default Re: Thermostat problem
either the thermostat is not opening properly or the system was not bleed well.
I just bled my coolant last night its definitely a process to get all the air out, Took about 20 mins
Old Apr 12, 2016 | 12:09 PM
thugsbryan's Avatar
The thermostats are opening properly based on my tests, how do I bleed the system properly tho, my engine doesn't have a bleed nipple
Old Apr 12, 2016 | 12:24 PM
2kdrift's Avatar
Jack up front of car or park on an upward hill
remove radiator cap, fill coolant
start car let idle, leave radiator cap off fill coolant as needed,
I would also recommend increasing engine speed to 2k RPM and squeezing both radiator hoses periodically this is what worked best for me
Keep doing this until your not seeing any bubbles, dont forget to fill the overfill once your done filling radiator
put the cap back on let cool, double check coolant, take a 30 min drive, let fully cool and top off coolant one last time
Old Apr 12, 2016 | 04:54 PM
thugsbryan's Avatar
https://www.youtube.com/watch?v=zUpXgAJ1gjU
Ok will try, but i doubt that's my problem
Old Apr 12, 2016 | 05:23 PM
2kdrift's Avatar
your fan switch needs to read the correct coolant temp, if theres an air pocket it cant read properly. you say with no thermostat your fans work properly.
Are you monitoring your coolant temps via neptune? I do this in hondata and my fans come on properly and I can even change what temp they come on at.
Old Apr 13, 2016 | 04:00 AM
thugsbryan's Avatar
Ok i see, so installing the thermostat makes air get in d system? Cause my fans work fine without the thermostat, i monitor the coolant Temps from mechanical Guage
Old Apr 13, 2016 | 11:41 AM
2kdrift's Avatar
when u remove the thermo housing yes some coolant is drained and you are left with an air pocket, additionally you cant bleed the system properly until the thermostat has opened and there is coolant flowing through the system
while watching your gauge your thermo should open up arround 185 and the fans should come on at about 200F depending on what you have it set to in neptune stock switch is about 200F
when I monitored my fans with hondata they were comming on at 202F (stock sensor). I was able to lower this in my hondata software to 190F I assume neptune can do the same but I have not used neptune before
Old Apr 13, 2016 | 11:51 AM
thugsbryan's Avatar
Ok so I have to keep the radiator open till d thermostat opens to get out all the air? But by that the car will be pushing the water out the radiator, and even after my thermostat opens the fans don't come on, what will be the result if i have in the thermostat an run the fans straight, meaning keep dem on constantly
Old Apr 13, 2016 | 01:22 PM
2kdrift's Avatar
I wouldnt recomend keeping fans on at all times, the thermo switch is there for a reason (too keep your engine at optimum temp), when you reach higher speeds the natural air flow and fan will be fighting eachother. But you COULD do this if you want, your fan could fail prematurely since its running at all times.
did u disconnect the plug on the thermostat housing when u installed? please check to make sure its plugged in and not damaged. also try jumping the connection to verify the fans come on. Basically its a simple switch once its at correct temp it turns the fans on. if your fans come on when jumping it theres two possibilities 1. fan switch is broken 2. its not reaching the temperature at which it turns fans on
by the fact the your fans come on with no thermostat it sounds like the switch is working properly so either its not plugged in/broken connection or the fan switch is not getting hot enough
Old Apr 13, 2016 | 01:31 PM
thugsbryan's Avatar
Oh ok, the switch is working cause they fans come on quite fine without the thermostat, also I had jumped the fan an they came on too, I think the switch is not getting hot enough to turn on the fans wen i put in the thermostat
Old Apr 13, 2016 | 02:11 PM
2kdrift's Avatar
yup....so basically its not getting hot enuff
thats why i am recommending proper bleeding as air does not conduct heat like coolant does
monitor your temp gauge they should come on shortly after 200F
Old Apr 13, 2016 | 02:13 PM
thugsbryan's Avatar
Ok gonna try that and see, but i didn't need to bleed the system properly wen i didn't have in the thermostat an it worked fine
Old Apr 13, 2016 | 06:08 PM
Turbo-LS's Avatar
First question. Is it oem thermostat or aftermarket garbage? Oem only with thermostats
Secondly it sounds airbound. Bleed bleed bleed and bleed some more. Be sure all air is out of there. I purchased an airlift. Best tool ever bought. It vacuums down the cooling system and will show you if have leaks prior to filling the it fills the system for you completely air free. They run aroun 90 bucks
Old Apr 13, 2016 | 07:30 PM
thugsbryan's Avatar
It's oem thermostat, i will ave to try bleed it again and see, I was wondering if my radiator is partially blocked
Old Apr 14, 2016 | 03:13 AM
blackeg's Avatar
when u fill the coolant i always start by adding to the upper rad hose so it backfills the block right to the thermostat. then I go and fill the rad which brings coolant to the front of the thermostat. then u bleed
Old Apr 14, 2016 | 11:03 AM
Turbo-LS's Avatar
Do yu have any of the coolant hoses blocked off?
Old Apr 14, 2016 | 11:14 AM
thugsbryan's Avatar
Not really, I don't have the heater hose connected tho but it's not blocked, jus re route it to the head, I live in Jamaica so we don't use heater here
Old Apr 14, 2016 | 11:16 AM
thugsbryan's Avatar
Cud a partially blocked radiator cause the problem I'm having? I was gonna rod out my radiator and see
Old Apr 14, 2016 | 03:36 PM
Turbo-LS's Avatar
It sounds airbound for sure to me or air is being introduced into the system. Overflow tank filled before running the engine?
Old Apr 14, 2016 | 03:47 PM
thugsbryan's Avatar
I fill the overflow bottle to the full line not to the top of the bottle
Old Apr 14, 2016 | 06:00 PM
Turbo-LS's Avatar
Yeah that's fine just wanted to be sure you aren't sucking air back in when cap is closed
Old Apr 14, 2016 | 06:02 PM
thugsbryan's Avatar
Oh ok, can my water pump cause this problem?
tech410
15
Sep 22, 2010 05:22 AM
helldriver88
Jan 26, 2008 10:33 PM
GdmLaz
Jun 11, 2006 11:17 AM
EGhatched
Mar 14, 2004 04:17 PM
delSolLS
Jan 16, 2002 01:06 PM
