Techedge 1.5 rpm pick up for datat logging question
What wire on the ecu will i need to tap the green wire on my techedge for rpm pick up so that I can datalog. Thanks For your help
Re: Techedge 1.5 rpm pick up for datat logging question (ghettocrxsi)
Re: Techedge 1.5 rpm pick up for datat logging question (egmike)
it should go to one of the ignitor pins on the ECU. assuming its a CRX, it would be B15 or B17 (they're the same thing). your techedge unit will have two rpm inputs. use the rpm LO input.
