Does ECU use RPM reading?
I just picked up a honda civic hatch with an h22a swap. This will be designated for track/auto x. I'm working through some bugs now for it to be ready in the winter.
1. I has an autometer tach in it. It used to work before I bought it but now doesn't. It has a good 12v source and ground. I traced the green wire from the tach and it is hooked to the blue wire just on the other side of the firewall. Based on my research this should be correct. My question is the blue wire coming off the distriburtor. Is that used by the ECM? To trouble shoot I'd like to tap directly into that wire.
2. I should be able to use a multi meter with the car on to make sure there isn't a short circuit to that blue wire correct?
The Grumpiest
Re: Does ECU us RPM reading
So this is actually a "My aftermarket tach is not working any more" thread. You have signal. power and ground. That's it. The green wire is the rpm signal wire to the ecu.
https://www.google.com/search?q=civi...ient=firefox-a
You are quite correct. My autometer tach doesn't work anymore.
All wires hooked up. Question is does the blue wire from the distributor go all way to the ECM. i.e. can I tap into the wire right off the distributor to trouble shoot this. Right now the tach (green wire) is tied into the blue wire right next to the fire wall clutch master.
I'm trouble shooting if there is a short somewhere on the blue wire or if for some reason the tach just died.
It looks like I can tap into A21 on the ECU. But I should splice into that wire and keep the connection correct as the ECU uses this information.
Does someone have a more elaborate answer?
There are OBD1 and OBD2 P72 ECUs. Is yours OBD1? In this case, the ECU gets the rpm signal from the CKP sensor inside the distributor, not from the blue wire attached to the igniter unit.
It is an odb1 ecu. So the blue wire coming off the ignitor is not what I should tap into as another source to test the tach then?
If not where should I tap it into. From my research right now i believe it is plugged into the diagnostic port blue wire coming out of the firewall. Which isn't working at this point.
This was your original question:
The answer to this question is no.
Your current question is different:
Answer -- Use the blue wire in the test tach connector on the firewall to hook up a test tach. If it doesn't work, check whether you are installing it correctly and whether the blue wire is broken somewhere between the igniter unit and test tach connector.
Re: Does ECU use RPM reading?
Cool thanks for the confirmation.
I do have another question. Like I said the whole interior is gutted including the dash and panels.
I'm not sure if this was removed when that was done or the new ecu was put in but the diagnostic port that needs to be jumped to check the CEL is gone. Is there a way to readd this or check the CEL somehow?
Yea pretty sure. There is nothing in the footwell on the passenger side except the ecu (everything is down to the sheet metal). I felt around the ecu to see if was tucked someplace else but nothing that I could find that looked like the diagnostic port.
I created new post but it looks like I can ground D4 on the ECU to get the CEL to flash?
Also I talked to the previous owner and he said the the same time the tach quit working is when the CEL came on. So I'll have to check that before I do anything more with the tach. SOmething wrong with the distributor maybe?
