Is it ok to....
Old 11-26-2002, 06:44 PM
dinosa21's Avatar
Default Is it ok to....
Is it ok to run your car with out the FAST IDLE THERMO VALVE. the rason i ask is my frined taped his off, and mine just broke. I want to know if it will be ok if i run with out it for a couple of day until i get my order in? thanks
Old 11-26-2002, 07:00 PM
dinosa21's Avatar
Default Re: Is it ok to.... (dinosa21)
ttt
Old 11-26-2002, 07:04 PM
Good, Bad…I'm the one with the gun
Ash J. Williams's Avatar
Location: Trapped in time, Surrounded by evil, Low on gas
i blocked mine off (after removing coolant lines from the TB and IAC, the sensor freaked out and couldn't sustain the idle. i presume it soon after kicked it as i get code 14 once in a while. besides running a little bit rich when cold, there is no problems. as far as the coolant lines, i had no use for them, LA is plenty warm for it. but slight pinging disappeard under part throttle. do not disconnect it though, place a plate between intake mani and the valve.
good luck
stan
Old 11-26-2002, 07:11 PM
dinosa21's Avatar
Default Re: Is it ok to.... (90crxsi)
wow! i live in NM where its always hot but thanks for the post.
Old 11-27-2002, 12:04 PM
dinosa21's Avatar
i found out tha that part is $ 200 bills. What lines do you have to remove?
Old 11-27-2002, 01:22 PM
you mean coolant lines?
you will still have CEL from the valve itself. the lines come off the block to the TB and to the idle valve. bypass them both and rout the line back into the block.
stan
jamaicantourist
08-04-2009 08:36 PM
Lucid317
11-30-2007 04:49 AM
allmtrdc4
03-12-2006 04:01 PM
cnydelSolHybrid
07-13-2003 06:19 PM
X2BOARD
05-17-2002 12:57 PM
Quick Reply: Is it ok to....
