T04s+h22a?
Old Aug 3, 2003 | 11:39 AM
RudeLude's Avatar
Default T04s+h22a?
anyone know whet the spool time would look like if i used to straight to4s with .96 a/r on a built h22a with 9.0cr? also, what kinda power could that support?
thanks
daniel
Old Aug 3, 2003 | 12:01 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: T04s+h22a? (RudeLude)
with a .96 a/r spoll time will about at redline!!! the rear housing is for a supra or a car with a lot of nitrous!! also, at 9:1 you may never see full boost on it.
Old Aug 3, 2003 | 07:13 PM
RudeLude's Avatar
Default Re: T04s+h22a? (MotorMatrix.com)
so which t3/t04e should i go with if i wanna make close to 500hp? i'm thinkin of using a t3/t04e or a t3/60-1, which one would u recommend? and with what specs?
thanks
daniel
Old Aug 3, 2003 | 07:46 PM
I am a bad person
the sc61 is a great turbo. its efficient from 6 psi all the way to 30psi from what i have seen. you should make 500 on a lude motor under 20-22lbs no problem
Old Aug 3, 2003 | 09:59 PM
Senate1123's Avatar
what about an sc61 with a .69 a/r T4 turbine housing and T04s compressor cover? how will that spool?
George Ku
Full-Race.com
Dec 23, 2010 04:20 PM
GT61 this 1.8t
Jun 24, 2004 11:02 AM
DeeJay
Apr 2, 2003 07:58 PM
ludelvr
Oct 30, 2002 02:38 PM
Ri5e
Aug 24, 2001 07:59 AM
