switch from china to precision
Old Oct 19, 2011 | 01:29 AM
carlos8's Avatar
Default switch from china to precision
hi, i'm replacing my cousing eg gsr swap turbo (china) for a precision 5454e
.63ex/.60 comp .54 trim. The car have a .63ex/.60 trim.57 and quietly she
eat some hondas with the last in brands. Now my question, if i only switch
the turbos at the same boost level 16psi. The precision have to make more
flow that the china. Did you guys recomend lower the boost to start a new
setting or start from here?
any help will be appreciate
thanks
Old Oct 19, 2011 | 01:43 AM
terbear4god's Avatar
Default Re: switch from china to precision
id say yes just be on the safe side if not try and prove the ebay crap
(is sh..crap)
Old Oct 19, 2011 | 01:58 AM
carlos8's Avatar
Do you think turn off the boost controller and run the 14.7 psi spring is in the
safe way or swap to a 8psi spring.
Old Oct 19, 2011 | 02:00 AM
ZMX's Avatar
ZMX
To be safe, definitely turn the boost way down to start tuning.
The increased turbine flow will mean the engine will flow more air with the same manifold pressure (engine will be lean).
Also, the more efficient compressor will be making that boost less out of heat and more out of extra air (engine will be even leaner).
Old Oct 19, 2011 | 02:12 AM
carlos8's Avatar
ok, i going to swap the 8psi spring and start street tuning at 10psi. I'll post
later how it's work.
Old Oct 19, 2011 | 02:47 PM
turbohatch96y7's Avatar
I would think a whole new tune should be done since theres going to be diffrent values across the whole map. Be safe tune it
Old Oct 19, 2011 | 03:37 PM
carlos8's Avatar
agree, i made a new tune from the bin i make when i put the car together.
Ended at 14psi @ 16.5* on 93 pump. the car feel's a lot more fast but start
raining, more fine tune tomorow and saturday the track will talk. The map is very equal from the other, but i'm able to add more time with less psi.
jv88_dc2
Jun 12, 2012 03:49 AM
85
Sep 1, 2010 12:59 PM
blwn95civic
Apr 5, 2007 09:41 AM
TurbothisLS
Sep 8, 2002 09:31 PM
Integra187
Sep 21, 2001 07:13 PM
