Fuel cut issues, need help!!
Old Oct 20, 2012 | 07:44 AM
Chee_dog's Avatar
Default Fuel cut issues, need help!!
Hey everyone! I have been having this fuel cut at 5-6rpm with a flickering cel and its goes off on my b18c1 turbo civic after my recent tuned. It usually happened on third/fourth gear before the vtec engaged. I never had this problem until i took it to the shop to dynoed. I have try many varies options by reading a lot of honda forums but seems like i cant get it to fix. I have try swapping a new vtec housing/solenoid, new distruabtor, 255 walbro pump, and i still have this problem. Also, if you floor on low boost you are able to hit 8, and vtec engage but at the high boost you can't hit vtec nor pass to 8rpm. One thing i notice, if you slowly step on the gas you are able to pass vtec and get to 8rpm on 3&4th gear..but if i floor ill get a fuel cut at 5rpm before vtec engaged. Also, i realize my lanuch control is not steadily, it will bob up and down.. Like crazy. Please help!!!!! Ill appreciate ur help! Thanks
Old Oct 20, 2012 | 07:45 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Fuel cut issues, need help!!
Pull. The. CEL.
Old Oct 20, 2012 | 07:56 AM
Chee_dog's Avatar
Once u hit fuel cut it will shoot a cel then goes off. Idk how you would check that cell when its off?
Old Oct 20, 2012 | 08:03 AM
The Grumpiest
Keep the car running and pull it.
Old Oct 20, 2012 | 08:08 AM
Chee_dog's Avatar
Explains?
Old Oct 20, 2012 | 08:14 AM
The Grumpiest
How do you NOT know how to do this at this level of car modification?
CEL comes on. Pull car over. Leave car running. Jump service connector with a paper clip. Record the flashes. Some short. Some long.
Check codes against list found at this link
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
If you have a code reader even better.
Old Oct 20, 2012 | 08:22 AM
Chee_dog's Avatar
I think its only use for check engine that are on. My check engine isnt on, but once the fuel come it will shoot a cel and goes off.
Old Oct 21, 2012 | 05:19 PM
Chee_dog's Avatar
Help!!! Bump!!!!!
Old Oct 21, 2012 | 06:44 PM
Muckman's Avatar
Moderator in Chief
Follow the previous advice.
Old Oct 22, 2012 | 05:02 AM
v8eatrr's Avatar
Maybe your tuner set your rev limiter to low ad the cel is a shift light if it only comes in then?
Old Oct 22, 2012 | 06:39 AM
jdmadam's Avatar
What program are you tuned on? Do you have adjustable FPR? Go back to your tuner and explain to him whats happening.
Old Oct 22, 2012 | 07:11 AM
BigZeke5's Avatar
PLease see your tuner. If you didnt have an issue PRIOR to tuning and your having it AFTER the tune and it so happens that its happeing at vtec/crossover engagement, then he probably forgot to push a button or something. See your tuner. It might just be some thing small....
slimx
Engine Management and Tuning
Jun 15, 2013 01:25 PM
allenbarnette
Jul 10, 2008 01:11 PM
juice03
Jul 24, 2007 03:21 AM
turboH22Aakkord
Oct 8, 2005 05:15 AM
shotty
Jul 22, 2003 08:44 AM
