Suggestions Request: Camshafts for a stock B16A2 Engine w/ 80 shot of nitrous
B16A2. GSR trans. Bolt on's only. Solid mounts. Omni drag coil overs. 80 shot of nitrous. VP Import fuel. Question is what cams are suggested for spraying this application? Factory cams or more aggressive cams? This is a daily driven car, just every once in awhile a weekend warrior. Thanks in advance.
Re: Suggestions Request: Camshafts for a stock B16A2 Engine w/ 80 shot of nitrous
Spraying on VP import fuel will let that 80 shot hit real hard with the timing you will be able to run. I would probably drop in some Type R cams and some good valve springs, but nothing wrong as-is.
If your gonna swap cams anyway... GSR, Type R, CTR are all better than stock B16 cams.
But I wouldnt waste the time worrying about "nitrous cams".
1 Post
if you cant get any type r's, then go with skunk 2 tuner 1 cams and some good springs and retainers.
