stuttering engine
Old Jul 19, 2001 | 09:47 PM
  #26
VaporTrail's Avatar
New User
Default Re: stuttering engine (Double 06)
here's an easy thing that should help you figure it out. Go full throttle. If the symptoms are gone, it's probably the oxygen sensor. The ECU ignores the o2 sensor when in closed loop, so it wouldnt matter what it's reading. If it does not go away at full throttle, it could be running too rich. I don't think it's the MAP sensor, b/c if you fart on that thing wrong it throws a code That's all i can think of right now, good luck.
Old Jul 19, 2001 | 11:57 PM
  #27
SpeedBump's Avatar
Default Re: stuttering engine (VaporTrail)
My car seems to be acting the same way. I just put my turbo on like two weeks ago. I thought maybe it was my clutch giving out. I haven't been able to get on it yet because I just put my clutch in. It only acts up when the car reaches normal temperature. It bogs like crazy at low rpms. It vacuums at like 18 and what not. I replaced my fuel pump when I put the turbo on so I know that's not the problem. Any suggestions, I have no cel codes.
Old Jul 20, 2001 | 07:02 AM
  #28
KJ's Avatar
KJ
Default Re: stuttering engine (SpeedBump)
When are you supposed to change the ignitor?
Old Jul 20, 2001 | 07:19 AM
  #29
veejay's Avatar
New User
Default Re: stuttering engine (KJ)
i changed my ignitor when I noticed the car not responding to throttle... it got worse and worse then finally died. Theres a way to check the ignitor using a multimeter, and the tolerances should be in the Helms manual.
Old Jul 20, 2001 | 08:08 AM
  #30
rtype11's Avatar
Default Re: stuttering engine (GSRwBOOST)
drain the muffler bearings and drain the flux capacitor..
As far back as I can remember muffler bearings is my line...pls feel free to use it, but atleast know what you are talking about - muffler bearings do not need draining they need to be high speed polished and repacked!!!!!!!
Old Jul 26, 2001 | 06:37 AM
  #31
KJ's Avatar
KJ
Default Re: stuttering engine (veejay)
Is there any way you could let me know the values I should get when using the multimeter on the Ignitor? I don't have a helms manual handy.
Thanks!
daxlasaint
Nov 4, 2016 03:39 PM
paranemertes
May 11, 2015 09:46 PM
blackcivic11
17
Sep 18, 2009 08:15 AM
johnjohn072002
Jun 7, 2007 01:04 PM
Andrew 825SM
Oct 20, 2004 09:52 PM
