striped stud how to get stud out
Old Apr 5, 2006 | 06:04 PM
blackccoupe's Avatar
Default striped stud how to get stud out
hey guys on my t25 dsm o2 housing the stud striped, so i got this bad exhaust leak, seeing as only one stud is useful how can i get the bad one out and can i just use a regular bolt let me know guys
thanks
Old Apr 5, 2006 | 07:21 PM
Default Re: striped stud how to get stud out (blackccoupe)
anyone? don;'t really want to buy a new o2 housing
Old Apr 5, 2006 | 07:31 PM
Muckman's Avatar
Moderator in Chief
vise grips
Old Apr 5, 2006 | 07:39 PM
JDMTurboEG6's Avatar
stud remover, not sure if sears would have it but if you know any tool dealers they'd have it.
Old Apr 5, 2006 | 08:31 PM
slowturbocx's Avatar
you will have to heat up the housing around the stud with map gas or a torch and use the vise grips to move it back and forth until you free it.
o also use some spray oil threw the studs it will help.
Old Apr 6, 2006 | 04:08 PM
Default Re: striped stud how to get stud out (slowturbocx)
k i will tryo to heat it up then use vise grips thanks guys
Old Apr 6, 2006 | 04:13 PM
shortyz21's Avatar
try a pipe wrench if u got it, works a hell of alot better then vise grips.
Old Apr 6, 2006 | 05:58 PM
Mugencrxsir1's Avatar
Default Re: striped stud how to get stud out (shortyz21)
It's called an "easy out" bit, Rigid sells the best kit(Yes the same company that makes the power tools). You just drill a small hole into the stud, and drive in the "easy out", and twist the stud out. I know it's a huge pain in the ***, I had to replace a stud for my b16 head, it was snapped off during shipping.
teepo112
Apr 16, 2011 01:39 PM
iheartintegras
Jan 8, 2007 12:15 PM
95GSRTT
Apr 30, 2005 05:57 PM
carsaregood
Apr 23, 2004 01:18 AM
Turbo R
Dec 1, 2002 04:20 PM
