Broken exhaust mani stud
Old Jan 5, 2007 | 01:46 PM
iheartintegras's Avatar
Default Help - Broken exhaust mani stud
I've searched and read a lot, still can't get it out. Tried vice grips and a stud extractor. I can't get a drill in there to tap it. Unless anyone knows of a really small drill. Any help will be awesome
Modified by iheartintegras at 6:08 PM 1/6/2007
Old Jan 5, 2007 | 02:03 PM
Got_soy's Avatar
Default Re: Broken exhaust mani stud (iheartintegras)
go tighter with the visegrips or try to double nut it
Old Jan 5, 2007 | 02:06 PM
can't fit 2 nuts on it
Old Jan 5, 2007 | 02:48 PM
Hondaen's Avatar
This has the potensial to be a big problem.
There is dirt in the threads, ripping up aluminium and jamming it togeter.
Get yourself a stud remover. It locks around the stund with a wheel. You may remove the shield and alternator to get it fit.
Then, spray thin oil into the threads.
Use a impact gun to loosen the stud. The impakt gun uses small pulses of torqe and looses the stud. If you use a big wrench, the torque may rip the stud in half.
If you are luckey, this will work.
Do not try heat from a act. oxy torch. The heat will make the stud harden when cooling and you may not be able to bore the stud out if that is the last way.
Good luck.
Old Jan 5, 2007 | 03:00 PM
Default Re: (Hondaen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaen &raquo;</TD></TR><TR><TD CLASS="quote">This has the potensial to be a big problem.
Good luck.</TD></TR></TABLE>
I tired a stud remover but the stud wasn't long enough to reach the wheels. Maybe I can find a different kind of stud remover.
I can't fit any large tool in there.. motor is still in my car.
Old Jan 5, 2007 | 04:31 PM
dmotoguy's Avatar
Default Re: (iheartintegras)
long shot.. but if you have a tig you could weld an extension on it.. i had to do that a few months ago.. it was tough to get it clean enough to weld.. and it took a few tries before I got a good enough weld to get it loose with an impact gun.
Old Jan 5, 2007 | 04:39 PM
Hamstr323's Avatar
Default Re: Broken exhaust mani stud (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">go tighter with the visegrips or try to double nut it</TD></TR></TABLE>
worked more that a few times lol
Old Jan 5, 2007 | 04:50 PM
went and got some real nice vice grips. didn't work
Old Jan 5, 2007 | 06:23 PM
FIGARILA's Avatar
get some craftsmen thin style bolt extractor.... work for me.
Old Jan 5, 2007 | 08:51 PM
few other people recommended that, gonna get it tomorrow. ty
Old Jan 6, 2007 | 02:08 AM
Flashmn's Avatar
Did you try one of these?
Old Jan 6, 2007 | 04:57 AM
nope, where can i get one of those?
Old Jan 6, 2007 | 08:13 AM
Flashmn's Avatar
try a tool store, they work great. The more you apply twisting force to it, the harder it clamps on. We removed some real rusty studs from an old escort engine with it.
Old Jan 6, 2007 | 09:40 AM
I'll look around for one, thanks
Old Jan 6, 2007 | 12:04 PM
VRD^don's Avatar
your new best friend when it comes to stripped/broken studs/nuts...
http://www.sears.com/sr/javasr...e=Yes
Old Jan 6, 2007 | 05:08 PM
Default Re: (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">your new best friend when it comes to stripped/broken studs/nuts...
http://www.sears.com/sr/javasr...e=Yes</TD></TR></TABLE>
Bought it today, didn't work
Old Jan 6, 2007 | 05:52 PM
VRD^don's Avatar
it should of..you try the right size??by looking at your pic..there should be enough stud showing to get it out..
Old Jan 6, 2007 | 08:10 PM
yes 8mm, it wouldn't grab
Old Jan 7, 2007 | 02:41 PM
Flashmn's Avatar
Just get the tool I posted, I'm 99% sure it would come out with it.
Old Jan 7, 2007 | 04:19 PM
NormanBates's Avatar
Default Re: (Flashmn)
double nut it! get the first nut all the way down....it looks like you've got plenty...
Old Jan 7, 2007 | 05:06 PM
bart2546's Avatar
Default Re: (KillerAccord)
The bolt outs really only work if there is a head on the bolt and it's just stripped. I'd suggest the other tool someone suggested on here.
Old Jan 7, 2007 | 05:11 PM
Got_soy's Avatar
with the vice grips, tighten down as mush a possible. make to tight to close with your hand and hti it closed with a hammer.
Old Jan 7, 2007 | 06:55 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">Did you try one of these?
that has saved my *** a few times and it's like $10
Old Jan 7, 2007 | 07:27 PM
VRD^don's Avatar
Default Re: (F I G A R I L A)
try hammering the next smallest size bolt out on to it..this worked for me when i had to take out some grinded down flywheel bolts..and the bolts didnt show as much as your studs..
Old Jan 7, 2007 | 08:03 PM
Can't fit a hammer in there. I said expletive it and put my **** back together
